07 Ultra won't run?
Old Aug 10, 2007 | 10:13 PM
rockhard69's Avatar
rockhard69
Default RE: 07 Ultra won't run?
Harley had a recall on 02 ultras for one of the relays overheating and shutting down, once it cooled it would work again. they changed them out and the problem went away. When the relay shuts off the rest of the lights would stay on but you would not be able to start the bike. It would shut down anytime it felt like it and it might restart on the first try or you would have to wait 10 minutes. they might be having the same issue again. have your dealer check his maint noticies, hopefully this helps.
Old Aug 10, 2007 | 10:22 PM
Taterdog's Avatar
Taterdog
Check all your grounds coming off the battery, starter, etc. Sounds like you're good until you need the starter. Sometimes they get paint under the connections when building the bike. Replace the washers with star washers that dig into the metal. If you've added any accessories and this didn't start until after you added them, check them too. Let us know what you find.
Old Aug 13, 2007 | 10:27 PM
RodeMine07's Avatar
RodeMine07
Stage III
Well, got my problem resolved (I think) by Pikes Peak H-D here in Colorado Springs; they found that the positive terminal post had the screw (bolt?) installed incorrectly; they retapped it and put it back in (boils down to a loose connection that wasn't immediately visible, I guess) -- now the Electra Glide seems to be working fine. Hope you found the problem with the Ultra and that it got resolved.
Old Aug 13, 2007 | 10:31 PM
Taterdog's Avatar
Taterdog
Good deal, man, glad you found it. It's the little things that seem to drive us crazy the most!
Good riding.
Tater
NHHog
Mar 12, 2012 08:32 PM
mike06train
Jul 6, 2011 10:36 PM
rodmodder
Aug 28, 2008 08:11 AM
furnaceman
Jul 28, 2008 09:23 PM
07 Ultra
Jul 9, 2007 11:29 PM
