chrome inner primary #
Old Nov 12, 2021 | 07:28 PM
hattitude's Avatar
hattitude
Originally Posted by hdman6
So I went to the dealer today. Seems the part i need 60739-07 is now obsolete. I looked online at the Harley parts and it says not available. However plan "B" was kicking in gear. Dealer said they have a chrome plater that they can send my inner primary out to for 300 bucks. So that is the plan. Next question is this . since all that will be removed, should I have the Shift seal replaced?. Do they dry out with age etc? this would just be a preventive measure since its apart already.
You talking about the seal in the trans....?? I wouldn't bother with that if it isn't leaking. I would however, replace the shift lever at the trans... When I took my primary off, I installed a Baker shift lever in place of OEM... it's sturdier, grips the shifter shaft strongly, and avoids the problem of when the shift shaft wears, gets loose, and then needs to be replaced...
https://bakerdrivetrain.com/products...nt=23522349379
Old Nov 13, 2021 | 10:39 AM
Bingee's Avatar
Bingee
Why don't you check eBay? I know for a fact that there are some listed either new or exchange plated.
Jessie
May 14, 2011 03:58 PM
Egldr05
Jan 19, 2009 03:36 PM
dawg
Apr 30, 2008 02:46 AM
radrex
Apr 16, 2007 01:14 AM
GMONEY220
Nov 22, 2006 09:59 PM
