Battery replacement
Old Dec 30, 2022 | 09:25 AM
  #31
hattitude's Avatar
hattitude
Originally Posted by BelchFire
I have bought three Autozone Duralast batteries and none of them have lasted over 3 years. I have one of them dead now. Looking for a Deka/East Penn now.
I'm confused by the difference in a TX-30L and a TX-30LA. One is 6-13/16 tall and the other is 7-1/2 tall, yet both are listed by application for a Street Glide. What gives? Which is the correct height?
I am not familiar with the TX30L v TX30LA differences.
I found this chart on an Energizer Powersports battery ad. There does seem to be a height difference, but I don't know why. This chart mentions a "17mm height adapter" and I have no idea what that means....???
All else is the same between the two according to the chart.... I'd measure the OEM battery and pick the one nearest in size..
Old Dec 30, 2022 | 09:37 AM
  #32
man4mopar's Avatar
man4mopar
I put a Noco NLP20 lithium battery in my 2006 Wide Glide in 2021. Thing is so light one might think is a empty plastic case. I didn't do voltage checks while starting but observed near zero hesitation on start up meaning the voltage is dropping less than the AGM batteries I used before. I traded that bike off mid October with that battery still operating as new. No experience long term but wouldn't hesitate buying another, weight savings and ease removing installing is a major plus in my opinion.
https://no.co/products/lithium
Old Dec 30, 2022 | 09:45 AM
  #33
Rocking_it's Avatar
Rocking_it
I will never buy another battery from the auto parts store. Bought one from O’Reilly and lasted a little over two years.
Old Dec 30, 2022 | 09:46 AM
  #34
brakeless's Avatar
brakeless
Did you use a tender on them? I've always used a tender and had batteries last a long time. As for the height difference, do you have room for the taller one? What is the height of your current battery?
Old Dec 30, 2022 | 09:50 AM
  #35
Rounders's Avatar
Rounders
I get 7 years out of agm, and acid, I would not bother with lithium at this price point.
I heard a claim it started big motors better. Yes a motor.
If lithium goes to sleep in cold weather, I have heard you can unthaw them by turning lights on for a little bit.
Old Dec 30, 2022 | 12:00 PM
  #36
Ssitruc's Avatar
Ssitruc
Some batteries come with a plastic "spacer" to sit the battery on so they are a certain height, if they have to be "X" inches tall, for everything to fit and sit tight, or whatever. Got one with a battery I bought for something... not much to them, just a plastic base it sits on.
this is an example, the one that came with mine was not even this "elaborate"
Old Dec 30, 2022 | 12:26 PM
  #37
Rocking_it's Avatar
Rocking_it
Dont lie I saw you and your brothers in the parts store buying a lithium yesterday. Got a pic to prove it.
Old Dec 30, 2022 | 12:30 PM
  #38
brakeless's Avatar
brakeless
Why do I hear banjo music when I look at this? I'm sure Pa calls their mother "Sis".
Old Dec 30, 2022 | 12:54 PM
  #39
Dynamick's Avatar
Dynamick
"Unthaw" = freeze. One of those cringeworthy sayings.
Cross-thread points
Old Dec 30, 2022 | 03:03 PM
  #40
Max Headflow's Avatar
Max Headflow
[size=13px]
[/size]
While I have had good LI batteries. The NLP20 didn't do too well in a 131 FXR TC, 2KW starter, 2 gauge cables bike. It will be tired in a smaller 113 evo...
