Street Glide Media Compartment
Old Dec 17, 2021 | 07:23 AM
702's Avatar
702
Default Street Glide Media Compartment
Would anyone happen to know if the iPhone 13 mini fits in the (2019) Street Glide media compartment, plugged in & with the door closed?
Old Dec 17, 2021 | 07:55 AM
ZBoT's Avatar
ZBoT
My iPhone 12 mini (which is basically same size as 13 mini) fits with room to spare. I do use a 90-degree usb cable but not sure that's even needed. You should have no issue fitting this phone in the compartment.
Old Dec 17, 2021 | 08:12 AM
702's Avatar
702
Cool beans, thank you.
Old Dec 18, 2021 | 06:26 AM
StreetGlide2021's Avatar
StreetGlide2021
I upgraded my iPhone to a 13 pro and had the same concern. It fits (left side only), and the door closes with a regular USB cable.
Old Dec 18, 2021 | 06:33 AM
dajogejr's Avatar
dajogejr
Yes, it’ll fit with room to spare. My iPhone 12 Pro fits with case without issue.
Are you putting it in the compartment just to have it there, or to connect via USB for CarPlay, music, etc?
Buy once, cry once…this is the ticket. A few members suggested it and it works outstanding for my 19 limited.
https://cplay2air.com/?gclid=Cj0KCQi...4aAjx8EALw_wcB
Keep the phone in your pocket, jacket…or I have a RAM mount for it on my handlebar.
Works like a champ with iPhone and Boom GTS.
Old Dec 18, 2021 | 06:53 AM
Stormin70's Avatar
Stormin70
one of the benefits of using a physical cable is that you’re charging the phone while using CarPlay. I’ve heard that wireless CarPlay can be a real battery drain.
Old Dec 18, 2021 | 07:16 AM
dajogejr's Avatar
dajogejr
Yep. And that CarPlay adapter has a USB connector on the end which I think is to charge…but it screwed up my connection so I let it be.
Spot on…long rides, it’ll drain.
However, if I need to charge my phone I have a cigarette lighter adapter and I just plug that in the fairing and run a cable.
Great point stormin indeed…. LONG rides or if you hop on and have little charge…may not be for you.
The biggest killer of phones is the screen being on, then data pull/push.
I will say this… with several different cables, all higher end …not crap quality, before I used the car2play, I’d be riding along, hit a few bumps (yeah….Michigan roads) and the CarPlay would stop.
With this wireless interface and the phone in the identical spot, RAM mount on my handlebar, same crappy roads…it has never stopped playing once from jarring bumps. Just another side of the coin!
Old Dec 18, 2021 | 07:19 AM
702's Avatar
702
I installed a WHIM couple years ago, long before that device became available.
The reason I asked about fitment is because I've been getting text messages from Verizon with offers to upgrade from my 10 xs Max. They started at up to $350 off for a new 13 and it gradually increased it to $800 off over the last 6 weeks or so. I didn't care much for the size of the 10, but it worked great so I dealt with it. But, with their latest offer it made the 13 mini free. It will be here Tuesday.
Old Dec 18, 2021 | 07:23 AM
SGjoe0024's Avatar
SGjoe0024
Stage III
Default Tuner?
I recently got a 21 Street Glide Standard,, after 2500 miles, I put RineHart 4 inch slip ons, and screaming eagle air filter, I was told if I didn’t do full exhaust, the tuner is really a waste of money, I love the sound, havent noticed much performance difference, although I am happy so far with the 107,, any opinions on if tuner is needed or would make a difference? Thanks for any advice!
Old Dec 18, 2021 | 07:36 AM
702's Avatar
702
Yes, you should get the tuner, and just so this thread goes off topic even further, don't listen to the weirdos that think synthetic oil is better than a coked up hooker because they're wrong. Plain old dino oil is the best for these tractor motors.
