Inner primary case differences
Old Dec 17, 2021 | 11:05 PM
Engine_oil's Avatar
Engine_oil
Stage III
Default Inner primary case differences
Whats the difference between inner primary case 60677-07a and inner primary case 60677-07
Old Dec 18, 2021 | 03:49 AM
Mongo1958's Avatar
Mongo1958
I do not know. However, the outer primary cover for my bike has been updated to an A as well. I know this because I recently replaced it. The only difference is the oil deflectors are now cast into the design instead of plastic glued on parts.
I'm sure there is a change to the design of the inner cover. It could be minor but there is a change somewhere. Try looking at photos of both and compare them.
Old Dec 18, 2021 | 08:45 AM
hattitude's Avatar
hattitude
It could be hard to tell without a side by side comparision... they may in fact be the same...
Harley changes the letter of the suffix on a part number, for different reasons.
Sometimes it's a running production change that can be significant.
Sometimes it's a minor change
Sometimes the part doesn't change at all, it signifies a change in the part's vendor...
If the part #60677-07 no longer shows in the parts finder for your application, but the part #60677-07A shows instead, it's a superseded part #. That means they both fit the application, and the "07A" part is the new part number and the "07" part number is no longer in production....
Hope that helps...
Old Dec 18, 2021 | 01:18 PM
Engine_oil's Avatar
Engine_oil
Stage III
thank you for replying I figured it was a discontinued part number that was replaced by the other simply cause i couldn't find new 60677-07 just used but had new 60677-07a all day.
Old Dec 18, 2021 | 02:45 PM
Mongo1958's Avatar
Mongo1958
if I was going to replace the inner cover I'd go with a chrome one unless you like the black one🤪
Old Dec 18, 2021 | 05:51 PM
dawg's Avatar
dawg
I believe the revision A for the outer primary cover is the one where they molded in the oil chute for the compensator and the regular -07 was the one without where you had to glue in the black piece from the SE comp kit. Not sure about the inner primary update.
Old Dec 19, 2021 | 02:48 AM
Mongo1958's Avatar
Mongo1958
Figure it out yet?
Old Dec 19, 2021 | 10:40 AM
Engine_oil's Avatar
Engine_oil
Stage III
As far as I can see no changes and thanks everyone for replying I love these forums but will have the new one soon so I will update the differences then.
jurgie
Nov 12, 2024 09:28 PM
Craigsameer
EVO
Nov 30, 2021 01:37 PM
harley2390
Touring Parts
May 5, 2021 06:01 PM
Sleeps In Trees
Sep 7, 2008 03:02 PM
