Hi guys i ride my bike everyday. I got on it earlier and cranked it up and started down the road. I was coming to a stop sign and she just cut off. Now it won’t crank over. I can turn the ignition on and hit the start button but it turn over. Can anyone help.
Same thing happened to me on the first ride in the spring. Fired right off after a top up charge, ran some errands stopping and starting no issue. Stopped at the last stop sign before home and the bike died, helpful neighbour brought out a jumper pack-still no go and had to push the bike the rest of the way home. Battery was totally pooched ( no surpise it was at least eight years old), replaced it the next day and all was good. Check your battery connections first, have had a bit of corrosion and looseness also stop a bike dead.
These modern batteries just fail totally without warning like that. No early warning signs like slow cranking etc. They are very delicate inside and once a plate or connection has eaten through and fractured, bingo! no more volts. Just like that.
PITA. I ended up buying a battery load tester and do a check at each oil change and before any long trips. It's still no guarantee though. Seems like its the one area where technology has gone backwards.
Throw the battery on a 2amp charger , not a battery tender , when it's fully charged , take it in and have it load tested , most places will do it for free .
Just knowing the battery is good will give you peace of mind , then keep all your connections tight and clean , both ends .
I always recommend keeping a can of electrical contact cleaner , check for corrosion periodically . Battery cables . fuse box / fuses , connectors , relays etc .
