Shifter shaft Bushings
Old May 3, 2022 | 10:44 AM
itsmf's Avatar
itsmf
Default Shifter shaft Bushings
For a 2009 Ultra,where are you guys getting your shifter shaft bushings?
Thanks for any help.
Old May 3, 2022 | 10:47 AM
vizcarmb's Avatar
vizcarmb
You talking about the spacers that go through the spline? I just get the rubber ones that the dealer stocks. If you want fancy metal chrome, then ebay
Old May 3, 2022 | 11:11 AM
Ultra103's Avatar
Ultra103
I bought my bushings at Harley, along with a new shaft for around $30 all in. I drilled the boss and added a grease zerk while I had the old shaft out. Also added an o-ring on each end of the shaft and a wave spring on the outboard side of the rubber spacer.
Old May 3, 2022 | 11:13 AM
Ultra103's Avatar
Ultra103
Old May 3, 2022 | 12:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
HD has them labeled as "Bushing, brake lever" p/n 42642-00A. Last I bought some the package was under $4.00
Old May 3, 2022 | 01:06 PM
Ultra103's Avatar
Ultra103
Are you thinking of the plastic bushings for the brake and clutch lever, or the shaft attached to the shifter arms?
Old May 3, 2022 | 07:48 PM
seniorsuperglideE8
Bushings for the shaft that the foot levers are attached to, note one end is slightly beveled to fit into the housing on the primary a little easier. Look at Ronnies parts drawings for your bike.
Old May 3, 2022 | 11:25 PM
Highway Handler's Avatar
Highway Handler
Get the bushings from Harley.
I would buy a new greaseable shifting shaft from Pingel.
Thats what I did, fixes it real good and built to last.
Old May 4, 2022 | 12:03 AM
MotoJockey's Avatar
MotoJockey
Didn't know there was such an animal........... nice! Thanks.
https://www.denniskirk.com/pingel/gr...8aAg2SEALw_wcB
Still probably just install my own Zerk like @Ultra103 did tho.......
Old May 4, 2022 | 05:11 AM
jake24lt's Avatar
jake24lt
For $90, I'll drill and tap too!
