2022 Roadglide special ignition switch issue
Old May 13, 2022 | 09:42 PM
Mendoza96's Avatar
Mendoza96
Stage II
Default 2022 Roadglide special ignition switch issue
Hello everyone,
I am having an issue with my bike turning on. I have kraus risers with thrashn bars and a gauge relocation kit. I no longer have an ignition switch on the tree. Power is all set up through the ignition run button on right.
Everything has been working fine until today. I went to turn on the bike and nothing turned on. No screen, headlight, taillight, signals, gauge needles don’t move, no fuel pump priming sound.. nothing.
The bike recognizes the key fob because if I move the bike the alarm lights do not flash. If I move the fob away they DO flash. I replaced the battery in the fob anyways and still same problem.
If I hold down the trip button on the left housing it’ll go into accessory mode and that DOES work.
I want to see if any body knows of a quick fix for this?
Old May 14, 2022 | 06:50 AM
Hawg Runner's Avatar
Hawg Runner
Check main fuse, check power to run switch.
Old May 14, 2022 | 08:08 AM
skratch's Avatar
skratch
sounds like your rh switchpack is going out.
Old May 14, 2022 | 08:59 PM
Mendoza96's Avatar
Mendoza96
Stage II
You were right. Just got it back from the shop a couple hours ago
CoolBreeze3646
Aug 2, 2021 05:45 PM
CoolBreeze3646
Milwaukee Eight (M8)
Jul 29, 2021 08:39 AM
RoadGlideUltraStageIV
Oct 3, 2019 05:20 PM
theabominablenick
General Topics/Tech Tips
Jun 11, 2014 10:40 AM
TMike84
Sep 14, 2012 06:10 AM
