Front Bearing Gone
Old Jun 18, 2022 | 02:39 PM
  #41
620Jester's Avatar
620Jester
You did read everything that I wrote in my reply, correct? ... I appreciate your experience ... I am also a veteran mechanic ( ASE certified ) and operated my own shop ( successfully ) until I retired 20 years ago ... No where did I recommend or mention the use of a grease gun, bearing buddies or the like ... I was offering caution for all and conveying my own experience on the last go round during bearing installation using a set of All ***** bearings ( one had Zero grease in it ) Was I in error checking? According to you I must have been ??
I have read every post in this thread. I do understand you didn't mention a "grease gun". Nor was that comment aimed at you directly. I was simply saying a lot of farmers will over do it. I mean absolutely no disrespect nor discounting your experience as a mechanic. I just feel there is a lot of misleading information on the web or information that some uneducated (not so mechanically inclined) person will read and take as gospel, go home and just pack the **** out of a bearing that doesn't need it. Not to say that a purchased dry bearing doesn't need grease, but, how much grease? "Well, I read where a guy said fill it". How much is full? Understand?
If a person purchases a non greased bearing in a high speed or high load application like a wheel bearing, either he or the person selling the bearing is what I consider an uneducated person. You can spin a bearing and tell if it's got grease or not. If you can't then pay someone else to do the work.
Hopefully this makes sense and I'm not offending anyone. Ride safe folks.
Jes
Old Jun 18, 2022 | 09:18 PM
  #42
Highway Handler's Avatar
Highway Handler
[img]images/icons/icon1.gif[/img]Quote:
Originally Posted by Cosmic Razorback [img]images/kirsch/buttons/viewpost.gif[/img]
Here’s a tip if you every have an outer race stuck in a wheel or wheel hub. Weld a bead around the inside of it and it’ll shrink and fall out. This technique is used a lot for tapered roller bearing races in a dead hole where you cannot get behind it.
That is a fantastic tip that I'm going to file away in the memory bank. I've pulled many bearings, never one like that.
When you said that it made perfect sense in my head.
If you like that then try a stainless steel electrode it shrinks even more.
it is great for sheared off studs. Weld a flat washer on first then the largest nut that will work. If it is welded half decently you will be happy.
Old Jun 19, 2022 | 09:05 AM
  #43
NorthWestern's Avatar
NorthWestern
Yep! Learned these methods as a teenager, and used them throughout my career wrenching.
Haven't come across many that know the SS rod trick! Broken turbo flange studs in exhaust manifolds...it's like magic
Xczar
Aug 9, 2021 08:31 AM
EasternSP
2014-2024 Touring Models
Sep 29, 2018 07:03 PM
Am4wag
Apr 3, 2014 08:53 AM
brihvac
Apr 24, 2012 07:50 PM
brazos95
Mar 27, 2007 06:23 PM
