Help ....Throttle return at the sensor?
Old May 28, 2022 | 05:38 PM
apxpred's Avatar
apxpred
Default Help ....Throttle return at the sensor?
2015 RGS - Hopped on today and fired her up, noticed the RPM's were running at 2k at an idle. I rolled the throttle foreword past it's resting location and there's about 1/4" of rotation and the RPM's drop to normal. Yanked the grips............nothing going on here, but again rotating the small end portion w/ the teeth foreword dropped it back to where it's supposed to be however it snaps right back again. Any input appreciated !!
Old May 28, 2022 | 05:51 PM
GalvTexGuy's Avatar
GalvTexGuy
Not quite sure exactly what is happening, especially the part about snaps right back again.
Anyhoo…
Reset the TPS.
Turn ignition switch on for 10 seconds, then off for 10 seconds (Don't start engine).
Repeat a total of 4 times.
DO NOT TOUCH throttle while doing it.
Old May 28, 2022 | 06:10 PM
apxpred's Avatar
apxpred
Thank you sir................worked like a charm.
EdsRoadGlide2017
Aug 24, 2017 08:33 AM
kjc1134
Jun 8, 2015 05:51 PM
dobro
Apr 29, 2013 06:13 PM
bigdaddysdaddy
Apr 8, 2009 12:50 AM
Z_Stingray
May 27, 2008 07:34 PM
