Parasitic Drain?
Old Jul 3, 2022 | 11:40 AM
TriGeezer's Avatar
TriGeezer
Charge the battery full, and let it sit for 2 days. Then measure the battery voltage at the end of 48 hours.
Then fully charge the battery again, unplug the voltage regulator, and let it sit for 48 hours again, and then measure the voltage.
Use a real dmm not the built in voltage meter. Compare the two measurements. That will tell ya if the voltage regulator is causing the parasite draw…you can repeat this exercise on various other circuits to identify where you have parasitic draw.
Old Jul 3, 2022 | 11:47 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Modern bikes should be fine for a month or two with a good battery. Using a maintenance charger will only guarantee the last start will be when you leave home
FIrst, get a AC/DC/Volt meter that has say 10AMP draw.
There cheap. Put it in AMP and remove negative on battery and with everything off, hook in in series. You will see a spike as the connection is made but after 30 seconds, it should trim off to less then 150 milliamp.
If it doesn't, you have a drain. Probably, the wreck damaged the stator. Remove their 3 wire connectors from bottom of regulator and use ohm meter to make sure they are not grounded to frame.
Also make sure nothing has been connected to battery extra . I didn't see were its a new battery. Battery is pretty fragile inside
Old Jul 3, 2022 | 11:48 AM
Rounders's Avatar
Rounders
That would work. Dc clamp ons have gotten cheaper, but you still have to buy them.
Unplugging battery for two days will also test battery
Old Jul 3, 2022 | 12:01 PM
WP50's Avatar
WP50
Got anything like a run/brake /turn control module added?
Extra electronics or such added say an Amp for the stereo or such?
WP
extremeshot
Electrical/Lighting/Alarm
Sep 30, 2014 03:10 PM
harley_guy1995
May 23, 2012 10:46 PM
cr1340
Sep 20, 2011 08:19 PM
Tommybahama
General Topics/Tech Tips
Aug 31, 2010 08:32 AM
Bakersfish
Mar 26, 2008 08:05 PM
