Code Help
Old Jul 18, 2022 | 09:35 AM
Angryman's Avatar
Angryman
Originally Posted by Ultra103
Crank sensor. Replace that and your troubles will likely disappear.
You are the 1st person to say crank sensor. No one I have talked to and nothing I have seen while researching this has mentioned that.
Old Jul 18, 2022 | 03:09 PM
Angryman's Avatar
Angryman
Well, I got the intake seals and exhaust gaskets done. Also changed out the fuel filter for good measure. Cleared the codes, checked for leaks at intake and went for a 50 mile ride. Bike ran good with no stumbles, breaking up or backfires. Seemed to run a little hot. Leg felt hotter then usual. Not sure if it actually was or that it was just hot as ***** out. When I got home I checked the codes and leaks again. No leaks that I could detect but it had codes P0132 and
P0151. I am stumped. Might have to try the crank sensor. At this point what could it hurt.
Harpo568
Welcome Area Only
31
Apr 19, 2017 09:26 PM
notofthisworld
Dec 5, 2014 04:58 PM
Black_Hog
Apr 5, 2014 07:11 AM
harley0711
Jul 19, 2012 11:04 AM
kuxika
Nov 12, 2009 08:26 AM
