Adding accessory switches to the right side ?
Old Jul 23, 2022 | 04:44 PM
AydensPapa's Avatar
AydensPapa
Default Adding accessory switches to the right side ?
2015 Ultra Limited. How do I add accessory switches to the right side of the dashboard ?
I have 3 switches on the left side of the dashboard...fog Lights and 2 accessory on/off switches installed with the Harley Auxiliary Power Switch Kit on the left side panel (with the fuse box).
How do I add 2 matching accessory on/off switches on the right side of the dashboard ? Where does the plug on the right go to ?
Old Jul 24, 2022 | 11:50 AM
Ridercoach0412's Avatar
Ridercoach0412
gray six way molex for the P&A dash switch pack.
Old Jul 24, 2022 | 03:18 PM
AydensPapa's Avatar
AydensPapa
2015 Ultra Limited
I see that the left [105L] and right [105R] connectors go to the same connector [4] in the left side panel.
Is there one harness that connects 8 pins into [4].controlling left and right side accessory switches? I have 4 pins going into [4] for the left side accessory buttons?
or would I have to add female terminal sockets to the existing connector from the Auxiliary Power Switch Kit #71400106 in order for right side accessory switches to work ?
On the right side of the console, I have 3 blanks and no Switch Dash Panel Base. What Switch Dash Panel Base, Blank Switch and 2 Accessory Switches do I need to purchase ?
Old Jul 24, 2022 | 03:38 PM
TriGeezer's Avatar
TriGeezer
Here ya go….
https://www.harley-davidson.com/us/e...unt/p/71400106
Old Jul 24, 2022 | 04:23 PM
AydensPapa's Avatar
AydensPapa
I don't believe that is correct for the right side switches.
#71400106 does not include the Switch Dash Panel Base (I need for the right side) and the 4 pin wire harness included controls left side switches.
#71400105 includes the Switch Dash Panel Base for the left side, I don't know if it will fit the right side and the 4 pin wire harness included controls left side switches.
Old Jul 25, 2022 | 01:04 PM
lefty33's Avatar
lefty33
Don't think it will fit as the switch housing is shaped specific for right & left.
I used 71400129 on the right side of my RG. Says if fits '17-later Electra GlideŽ, Street GlideŽ, Road GlideŽ, Ultra Limited™ and Tri Glide™ models.
Old Jul 26, 2022 | 01:33 PM
AydensPapa's Avatar
AydensPapa
What year is your RG ?
Old Jul 26, 2022 | 02:02 PM
TriGeezer's Avatar
TriGeezer
BTW…your dealer parts guys can hook you up. Unless you are trying to find out what to order from Surdyke for a discount.
Old Jul 26, 2022 | 02:06 PM
bson's Avatar
bson
Just if you're not aware of it, there's also a bar mount housing: https://www.harley-davidson.com/us/e...it/p/70248-02B
Old Jul 26, 2022 | 04:01 PM
lefty33's Avatar
lefty33
My RG is a 2020. I now see your bike is a 2015 and this kit says it's for 2017+...not sure what changed from 2016 to 2017? May work...may not? If my memory serves me (which it doesn't all the time), I think some use a relay, some don't??
Also I was mistaken...apparently the switch base is the same for both R & L and it just gets flipped upside down from one side to the other...but then the logo on the button is upside down. Some guys run the buttons upside down, some pop them off and switch them. Here's a thread (long) that goes through all of this for your year bike. Take your time and read it all as I believe your answer is in there. Has individual part numbers for all the pieces...
https://www.hdforums.com/forum/new-r...tch-flhtk.html
And here's another one...
https://www.hdforums.com/forum/new-r...-switches.html
