Jerking, sputtering, and dead.
Old Sep 5, 2022 | 04:49 PM
SMR65's Avatar
SMR65
Being a carb u can pull the breather off and see if u are getting a good stream of fuel, when u twist the throttle. That would eliminate one possible problem.
Old Sep 5, 2022 | 04:50 PM
bson's Avatar
bson
Look down the cylinders after removing the plugs. If you see a pair of red eyes looking back at you you need an exorcist.
Old Sep 5, 2022 | 07:36 PM
hattitude's Avatar
hattitude
Originally Posted by mark busse
Enjoying a ride on my 06 Electra Glide in the sunshine when I gave it some beans to feel the roar and pull of the S&S T124 crate engine (carbureted).
Suddenly it started to intermittently jerk and sputter, even backfiring a couple times. I thought the battery terminal might’ve come loose, but after pulling over to check it wouldn’t start again (had to get it trailered home). Battery is new, terminals are tight, and it turns over, but sputters and coughs and doesn't want to run.
What would be the first things you would check before taking it to a shop?
Petcock is open, but it had occurred to me that a clogged fuel filter could be an issue. I only buy the best gas available, but weirder things could happen.
As mentioned, it's best to try to determine if you're missing fuel, spark, or compression... it needs all three to run..
But If you really feel it's a fuel issue, you can check two things quickly and easily... and it won't cost money....
1) I forget what years the Harley tanks were lined... but the liner has known to peel, and cause intermittent, then almost total fuel flow restriction. Look into your tank with a good flashlight and see if there are various sized "flakes" floating around.. If so you have a peeling tank liner.. I had it on my 2001 and heard of it on a 2003.. Just not sure when HD stopped lining the tanks..
2) You have a vacuum operated petcock. They can fail.. You need both the petcock to be open and vacuum to the petcock for fuel to flow. Check that the vacuum line between the carb and the petcock is in good condition, well seated on both ends, and not leaking vacuum needed for the petcock to allow fuel flow..
Good luck keep us posted...
Old Sep 5, 2022 | 07:39 PM
Max Headflow's Avatar
Max Headflow
Compression?
Old Sep 5, 2022 | 10:06 PM
Rounders's Avatar
Rounders
Crossed my mind being hot rod engine
Old Sep 5, 2022 | 10:58 PM
Highway Handler's Avatar
Highway Handler
What would be the first things you would check before taking it to a shop?[/QUOTE
First thing I would check before taking to a shop is my wallet.
I would check all the other stuff already mentioned before deciding to take to a shop.
I hope you get it fixed without it being a major problem.
Old Sep 6, 2022 | 08:00 AM
motorsickleMike's Avatar
motorsickleMike
6th Gear
I had the same problem on my older RK. Turned out to be the cam sensor in the nose cone had melted down. Luckily I was riding with a couple of buds 70 miles from home when it started acting up. Riding thru some swamps, no shoulders on a 2 lane road water on each side. Late afternoon with a line of bad storms heading right at us. Had 2 choices. One bud could ride home get his truck and trailer. 2+ hour turnaround. 2nd bud said I’d ride it till the sob blows up. Off we went, under 45 mph ran rough, was backfiring and shooting flames out the pipes. Over 45mph ran better but not good would not go over 55 without starting to stall out. Had 3 small towns to pass thru, couldn’t stop or might not get it started again. Lead bike would block intersections at red lights while two of us rode on thru. Finally made it to civilization and to a Harley dealer that was closing up. Pulled up to the service door and it finally died. No damage other than the melted cam sensor. I must have been living right or just damn lucky. Best of luck!
Old Sep 6, 2022 | 08:06 AM
Ultra103's Avatar
Ultra103
Not sure about the solution to your problem, but my GF saw the title 'Jerking, sputtering, and dead' and said "That sounds like a fun evening out"
Old Sep 6, 2022 | 10:34 AM
bm11's Avatar
bm11
How does it idle? I ask because throttle position sensors are a common issue as the wires get damaged during a bar install, which most bikes have. My bike was idling fine but started to hesitate when driving, which got pretty bad. I changed plugs and fuel filter, but it ended up being the TPS.
Old Sep 6, 2022 | 11:01 AM
Max Headflow
Bike is carbureted. No throttle by wire. Only sensors are Crank and MAP.
