Jerking, sputtering, and dead.
Old Sep 5, 2022 | 02:47 PM
mark busse's Avatar
mark busse
Default Jerking, sputtering, and dead.
Enjoying a ride on my 06 Electra Glide in the sunshine when I gave it some beans to feel the roar and pull of the S&S T124 crate engine (carbureted).
Suddenly it started to intermittently jerk and sputter, even backfiring a couple times. I thought the battery terminal might’ve come loose, but after pulling over to check it wouldn’t start again (had to get it trailered home). Battery is new, terminals are tight, and it turns over, but sputters and coughs and doesn't want to run.
What would be the first things you would check before taking it to a shop?
Old Sep 5, 2022 | 03:01 PM
buell95's Avatar
buell95
Sounds like a fuel issue try pulling the plugs a make sure they are not fouled
Iknow it sounds stupid put is the fuel petcock on ?
Old Sep 5, 2022 | 03:06 PM
BrokeWinger's Avatar
BrokeWinger
Does it crank and not start? Or not do anything at all?
If it does nothing, you may have a charging issue.
If it cranks but doesn't start buell95 could be dead on with fuel issue.
If it isn't a fuel issue it could be spark related. Sometimes Harley coils (or any coil for that matter) will "leak" once they warm up. Let em cool off and they work just fine. But will cut out again as soon as they warm up a bit.
Old Sep 5, 2022 | 03:36 PM
Screamin beagle's Avatar
Screamin beagle
Check the 3 basic requirements for combustion...fuel...spark...air. Pick one and eliminate it from the equation and so on. Ya got those 3 and still no boom boom then you have to dig a little deeper...maybe timing.
Old Sep 5, 2022 | 03:55 PM
ClifWideGlide's Avatar
ClifWideGlide
You didn’t say if it would crank or not or did any lights come on when ignition turned on? Also you said you checked the battery connections but did you check the ground going to the frame mount? I had a Dyna that had symptoms like you described and it was my ground wire from the battery to the frame connection.
Old Sep 5, 2022 | 04:13 PM
mark busse's Avatar
mark busse
Petcock is open, but it had occurred to me that a clogged fuel filter could be an issue. I only buy the best gas available, but weirder things could happen.
Old Sep 5, 2022 | 04:16 PM
mark busse's Avatar
mark busse
Battery is new, terminals are tight, and it turns over, but sputters and coughs and doesn't want to run. Checking the ground hadn't occur to me, but I'll take a look.
Old Sep 5, 2022 | 04:36 PM
bson's Avatar
bson
"Sputters and coughs" means you get occasional ignition? Check the spark plugs. How many miles since they were last replaced?
If they're clean, maybe consider replacing the coils. This would likely be one cylinder, so you could pull them both and see if one misfires.
Old Sep 5, 2022 | 04:44 PM
Rounders's Avatar
Rounders
Coil and cpk too.chrck for spark. If it starts after it coils could coil. I'd check spark,after tightening battery cable.
Little odd to me for carb bike to have fuel problem when running. Change plugs for hell of it.
Do you really need the s&s fuel filter? May need to check jetting if you remove. But I get idea every thing has fuel filters.
I'd check spark first since it turns over
Old Sep 5, 2022 | 04:46 PM
Rounders's Avatar
Rounders
Going to be dick. Not first guy to run out of gas
