Jerking, sputtering, and dead.
Old Sep 7, 2022 | 12:20 PM
  #31
hattitude's Avatar
hattitude
My guess... Carbed 124 SnS motor probably has a Super G carb.. Motor ate a backing plate screw..
Boy that would suck.....!
I was looking at web sites for Harley repair shops for older engines. There was one shop in Florida somewhere who posted pictures of "mistakes" they fixed. One set of pics was an engine that ate a backing plate screw.... I had never seen or heard of that before those pics... That damage was not pretty...
Old Sep 7, 2022 | 01:40 PM
  #32
tanksfbay's Avatar
tanksfbay
Stage I
Crank Position Sensor is my guess. I'm no mechanic by any means. On the contrary, I've been wrenching on bikes for less than a year, having just bought my first ride. That being said, shortly after purchase, my bike did the same thing you mentioned. Only difference is mine did the jerk, sputter, cough on a half dozen occasions over the course of a month before it wouldn't start again. But every time it happened, I was twisting the throttle pretty quick trying to get on 'er. Check to see if you're getting spark to the plugs. If not, I'll double my uneducated and inexperienced wager on the crank sensor being the culprit.
Old Sep 23, 2022 | 05:57 PM
  #33
mark busse's Avatar
mark busse
Thanks for the suggestions.
I confirmed power/connections, clean fuel and delivery, clean air filter, and strong spark. I swapped the plugs (which looked fine), leads, and coil in case they were the issue. Leakdown test confirmed good compression in both cylinders. I even looked for gremlins hiding in the cylinders (LOL). But ultimately it seemed likely to be a faulty crank position sensor so I swapped it out and boom, was back on the road! But other performance problems returned that have me stumped.
It runs pretty smoothly except it chokes and bogs when I give it heavy throttle, kind of like the S&S Super G carb was jetted totally wrong or accelerator pump wasn't working. The carb quite new and has been great all year, but just in case I gave it a good inspection and cleaning, checked for air leaks, even swapped out the jets. But it still runs like crap under heavy throttle, and in fact has occasionally sputtered and misfired again like the timing is wonky.
After consulting with a local Harley mechanic, we're starting to suspect maybe the Dynatek TC88 electronic ignition might be the culprit. Has anyone experienced that sort of thing? Could it be that when the crank sensor was failing it somehow sent whackadoodle signals to the ignition module that damaged its electronics? And if I have to replace it, is there a better option I should consider to pair with this S&S T124 LC crate engine? Or reckon I should just order a replacement TC88 and swap it out?
Thanks in advance for any ideas and guidance!
Old Sep 23, 2022 | 05:59 PM
  #34
mark busse's Avatar
mark busse
Bike ran great until a moment in a ride when I gave it some heavy throttle and it started to buck and cough.
Old Sep 23, 2022 | 06:00 PM
  #35
mark busse's Avatar
mark busse
Nope. I'm always careful to Locktite those backing plate screws and none were missing. Even inspected the cylinders and did a leak down test to confirm compression. Seems likely electrical in nature.
Old Sep 23, 2022 | 06:01 PM
  #36
mark busse's Avatar
mark busse
Originally Posted by cycleman11
Did the bike run fine at some point, or did somebody work on the bike and this event started. We need more info to help you out.
Old Sep 23, 2022 | 06:02 PM
  #37
mark busse's Avatar
mark busse
Originally Posted by FlamedFXR
Check for codes would be my first move.
Did get the code U1225 which I haven't exactly figured out. A short maybe?
Old Sep 23, 2022 | 06:16 PM
  #38
smitty901's Avatar
smitty901
Originally Posted by Rounders
Coil and cpk too.chrck for spark. If it starts after it coils could coil. I'd check spark,after tightening battery cable.
Little odd to me for carb bike to have fuel problem when running. Change plugs for hell of it.
Do you really need the s&s fuel filter? May need to check jetting if you remove. But I get idea every thing has fuel filters.
I'd check spark first since it turns over
Not every thing. 2015 Harley Street 750 has No fuel filter.
Old Sep 23, 2022 | 07:41 PM
  #39
Max Headflow's Avatar
Max Headflow
I had a CMC rocket 88. It came with a thunderheart ignition. At about 4500 RPM it would start cutting out. Guys that had them in the Indians at the time were simply programming the rev limiter real high and the ignition would work. IMO TH ignition has an issue where the limiter would cut in early.
I installed a Dynatech and the problems disappeared. For a couple years then it came back but this time a little different.. The lights would dim.. I got to hunting around and found that a wire going to the ignition switch had a crimp lug where the loop was broken from the crimp part. Fixed that and no issues after.
Make sure power to the Dynatech is good.
Another of something like that is simply water in the float bowl..
wtlawson8
Electrical/Lighting/Alarm
Sep 23, 2022 09:08 PM
Goat1987
Jul 8, 2017 08:05 PM
JeepBlk37877
Apr 7, 2017 07:57 PM
KINGASOBEE
Mar 11, 2017 09:50 AM
HDPursuit
Jul 27, 2009 04:03 PM
