Help Identifying Air Intake 2006 FLHRCI
The bike has not been tuned and I plan to do so this spring. Want to consider if I should upgrade the intake before tuning or if the one that is on the bike is a hi-flow intake. I've been looking at S&S products and while they aren't super expensive I don't want to spend the money if there is no benefit.
That is the Screamin' Eagle High Flow Stage I intake backing plate.... it is NOT the OEM backing plate..
They currently only make them in black or chrome, that is the older grey finish backing plate.
https://www.harley-davidson.com/us/e...kit/p/29400239
You can get the round, high-flow filter, either from K&N (gauze filter that you oil) or you can get the HD Dry element high flow filter #29442-99D (my preference)...
Add a cover and you have a high flow air cleaner set up.....
I've used that backing plate on several Twin Cam engines: an '01 carb @ Stage I, '03 EFI w/big bore kit & headwork, '12 EFI @ Stage II (cams), and a '16 EFI @ Stage I.
There is no need to change that air filter for any Stage I, II, or mild Stage III or IV.... I finally had to switch that air filter on my 2016 Bagger to an S&S Stealth with the large filter, because I went to a 124" crate engine w/ 58mm throttle body and it needed more airflow...
If you have that air filter with it's high flow filter AND a Screamin' Eagle Exhaust, you have a Stage I mod on your engine and would benefit from a good tune...
Enjoy...!!
