Swingarm lift stand
Old Feb 26, 2023 | 11:13 AM
MotoJockey's Avatar
MotoJockey
I agree on the scissor jack, or ........ for quick, easy, & cheaper.... something like this... it's rated @ 800lbs, but since it doesn't lift the entire weight of the bike, should handle a bagger...
https://www.summitracing.com/parts/p...AaApc8EALw_wcB
I welded up something like that back in the day for my 76 Sporty. Worked great and I got the material for free from work.........
Old Feb 26, 2023 | 05:38 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
He has many different versions, though they are called generations.
Common enough practice and tool for the dirt bikers and such. No, it is not well suited for porkers like touring Harleys.
Old Feb 26, 2023 | 06:07 PM
LQQK_OUT's Avatar
LQQK_OUT
If you just want something to make it easier to check the tire pressure, why not something like a wheel cleaning stand?
https://www.harborfreight.com/motorc...and-98800.html
Old Feb 26, 2023 | 07:13 PM
Hoginedgewood's Avatar
Hoginedgewood
how easy is the dismount?
Old Feb 26, 2023 | 07:24 PM
hamah's Avatar
hamah
Why use a stand at all? These work great. I mounted mine with a T stem to make for easy air fills as well. Granted more expensive than that stand but these are actually useful.
Old Feb 26, 2023 | 07:39 PM
NorthWestern's Avatar
NorthWestern
Make sure you put THESE in next time you do a tire change.
Old Feb 27, 2023 | 06:09 AM
IronAss's Avatar
IronAss
Not that one but I've been using those for over a decade and they work great.
I even modified one to take with me when I did a ride up to Alaska in 2010.
Old Feb 27, 2023 | 06:21 AM
Uncle Larry's Avatar
Uncle Larry
I still have my Duo-Lift .... Similar to what you've show except it lifts the complete bike off the ground
Old Feb 27, 2023 | 06:51 AM
eighteight's Avatar
eighteight
Originally Posted by Hoginedgewood
I love the idea of this for checking rear tire pressure on the dresser. I can't see it lasting long, but I can't see a big disaster if fails.
Motorcycle Lift Stand Trail Stand Rear and Front Wheel Easy And Portable-Third Generation New Design for Most Motorcycle Wheels https://a.co/d/hg8SXnt
Thinking I could roll the bike a couple feet faster than you could deploy that device
Old Feb 27, 2023 | 07:33 AM
NoRegerts's Avatar
NoRegerts
The description doesn't mention weight, but a reviewer claims that a 500lb motorcycle would be pushing the limits. My thought is, you're asking for trouble. Even if the lift could support the weight of the bike, the side stand isn't designed for that and you risk far worse things happening than the cheap lift failing.
There are better options.
Cigarmessenger
Apr 10, 2016 07:57 PM
STREET BOB JOE
Apr 3, 2014 08:23 AM
Fireslayer
Apr 12, 2009 04:46 PM
pandol34
May 14, 2008 09:21 AM
TexasBowhunter
Jan 3, 2008 07:47 PM
