Raising handlebars
Old May 31, 2023 | 06:37 PM
labou1's Avatar
labou1
Question Raising handlebars
Got a 2022 Street Glide and thinking of raising my handlebars about 2" for a more comfortable reach. Will all wires, throttle cable and clutch need extending or might there be enough slack. If so, other than the clutch extension, and maybe throttle, thinking of doing my own. Y
our thoughts?
Old May 31, 2023 | 09:47 PM
Black Ultra's Avatar
Black Ultra
On my UL, I installed the Khrome Werks 2+2 bars. The throttle is more than long enough, the controls wiring was just long enough, I had to extend the heated grip wiring. The clutch cable just barely made it and the front brake line was fine.
Old Jun 1, 2023 | 01:45 PM
HM_SanDiego's Avatar
HM_SanDiego
You should be good to go without needing any extensions for bars at oem+2” up to a 12” aftermarket bar - the most you might have to do is snip several tie-wraps currently managing the cables and wires under the front fairing and some gentle re-routing - check out KST Custom handlebars install videos on YouTube - they have a couple handlebar install videos that show in very good detail the entire process - very helpful for all mechanics.
Old Jun 1, 2023 | 02:30 PM
CaffeineBuzz's Avatar
CaffeineBuzz
you should be ok, I bought mine and had help from a fella who'd done it many times before.....we coulda made it work without the extension, but because we had it, it made fishing it through the neck of the bike a little easier...i did like you did and just went a little higher with 10's
Old Jun 1, 2023 | 06:59 PM
labou1's Avatar
labou1
Thanks all, I have taken a look and raised my stock bars and it doe seem there will be no longer cables needed. Am interested to see how 12" bars will work with my reach.
Old Jun 7, 2023 | 05:46 AM
labou1's Avatar
labou1
Default Raising handlebars
Well got my new bars, 12" with a 6" setback and pointed tops by V-Factor. It was a battle but got there I hope. I think the clutch cable and break line will be OK but it will be close. My throttle by wire cable is OK but also close and there was no way the left or right cable connections, had to lengthen them at least 12".
Softy 103
Oct 30, 2023 09:14 AM
HD-1
Apr 25, 2017 07:52 PM
inspectorbill
Jun 5, 2015 05:30 PM
128auto
Mar 12, 2012 09:47 AM
hddave2
Mar 10, 2008 08:56 PM
