'06 Ultra codes
Old Jul 8, 2023 | 07:56 PM
Strtbobber1's Avatar
Strtbobber1
Angry '06 Ultra codes
'06 Ultra with an 88 in it. Recently installed screamin eagle plugs and wires. Last weekend, went to start the bike after fuelling up. It fired once, then nothing but cranking. Determined that the coil quit. Got the new coil installed today, went for a ride and engine light came on. Checked and cleared codes. Went on another ride and engine light came on almost immediately. Misfire and sputtering at random. Codes are: p1353 and p1356. Anyone able to offer some insight? Cheers!
Old Jul 8, 2023 | 08:00 PM
kel03's Avatar
kel03
Have a read.
https://www.fuelmotousa.com/p-29661-...ble-codes.html
https://www.hdforums.com/forum/dyna-...353-p1356.html
Old Jul 8, 2023 | 08:13 PM
Strtbobber1
Thanks.
Old Jul 10, 2023 | 07:45 PM
Strtbobber1
Default At a loss 🤬
After installing a new coil, I have removed the fuel pump and confirmed no holes in the fuel lines. I've checked the injector wiring for breaks (Harley shop told me to check that). Checked crank sensor for physical damage, there's none. I don't have an adjustable multi-meter to ohm out the coil. Is there a way to confirm that my new coil is actually good? Any other **** I need to check? I'm at a loss.
Old Jul 10, 2023 | 08:35 PM
07UltraGuy's Avatar
07UltraGuy
Make sure that you have not somehow crossed the new plug wires.
Old Jul 10, 2023 | 08:37 PM
Strtbobber1
Good point, but that's definitely not the case here.
Old Jul 10, 2023 | 09:29 PM
WONKEY's Avatar
WONKEY
you need to get a cheap meter from harbor freight
it could be the new plug wires have too much resistance, try to put the old ones back on to see of the issues clear.
Gunny357
Apr 16, 2021 11:11 PM
mikestrikes
Mar 14, 2011 09:16 PM
in the wind-Murrells Inlet, SC
Jul 21, 2010 10:33 AM
HilllBillly
May 10, 2009 04:59 AM
smokeybud
May 26, 2008 10:13 AM
