Tire Plugs
Old Jul 14, 2023 | 07:49 AM
RKZen's Avatar
RKZen
For me it depends on the tire. If it's an older tire with more than half the recommended miles I'll replace. If fairly new then I'll plug.
I was riding with some buddies in the 4-corners a few years ago and I noticed a nail in the rear tire when we were at the hotel. The tire was fairly new with about 2500 miles on it. It was a slow leak, as I did the soapy water thing, so I plugged it with the kit I had. Checked everyday for a few days and was good until the tires needed replacing.
Old Jul 14, 2023 | 01:53 PM
rideonva's Avatar
rideonva
I've plugged my OEM tire while why I was waiting on my Dunlop AE to arrive. I've rode a little over 1200 miles on it. Plugs work but to be honest I'd change it on first opportunity, just for the peace of mind.
Old Jul 14, 2023 | 01:56 PM
vizcarmb's Avatar
vizcarmb
Pro tip. Buy your tires at Revzilla or CycleGear, have them mounted at CycleGear, and buy the insurance. Halfway through its tire life, shove a nail on it, report a claim, and boom you get a new prorated cost tire.
Plugs are hit or miss. Sometimes they work sometimes they don't. I usually have good luck with them, but recently they kept failing. A plug is a temporary fix until you get it replaced.
Old Jul 14, 2023 | 03:41 PM
lee4's Avatar
lee4
Originally Posted by NorthWestern
How do you know someone intentionally did this?
The tire was brand new. The portion of tread was unused, despite the screw. I just hadn't leaned it over at all yet. The screw was threaded in, not driven. The screw was brand new. The screw was fully inserted and facing entirely opposite of the wheel's direction of travel.
Act of God?
Old Jul 14, 2023 | 04:10 PM
Tommy B's Avatar
Tommy B
Assuming a nail or screw leaving a round hole in the tread (not sidewall), a properly inserted string plug (completely through the tread) will naturally mushroom a bit on the inside of the tire when pulling the inserting tool out. No way it's coming out. I've used plugs for decades and never had a problem for the life of the tire. Well, did have one leak but that one was inserted by a mechanic at a truck stop, not me. YMMV.
Old Jul 14, 2023 | 04:15 PM
Stiggy's Avatar
Stiggy
Mushroom plugs only for me. (Look at one after the tire's done from the inside. It's going no where at any speed.)
As to deliberate action on the OP's bike? Not likely. It may look deliberate but if I want to screw with you or your bike, a slow leak from running a screw into a tire (with a portable screwdriver?) is not the way I'd go. Way quicker ways to accomplish the same result.
Old Jul 14, 2023 | 04:25 PM
hardheaded's Avatar
hardheaded
Never had a problem with a plugged tire. I did one time have a small finishing nail in my 21 inch tire on my old shovelhead. I broke the bead down and pulled the tube out and patch it without removing the front wheel. I kept thinking about this repair for quite a few miles after that. But i had to do what i had to do to get home. I ended up running it like that for a few years after that. When i broke the wheel down to replace the tube and tire all was fine with my patch.
Old Jul 16, 2023 | 07:33 AM
Ultra103's Avatar
Ultra103
Ask how many people have had a plugged tire fail. That'll be a better way to get to your answer.
As for me, I've used rope plugs in every type of tire I've owned (including a GSXR racing tire) and NEVER had one fail in over 35 years. I don't replace tires just because they had a nail / screw.
Old Jul 16, 2023 | 09:27 AM
StoneTrekker's Avatar
StoneTrekker
Preference for mushroom plug or conventional string plug? Just interested in hearing from those with experience.
Old Jul 16, 2023 | 10:09 AM
Goldstar225's Avatar
Goldstar225
I've used the mushroom plug on three occasions. Once on a bike, once on a truck tire and once on a trailer tire. No failures.
