Compensator for an 09
Agreed... but it does have a small amount of cushioning that a solid sprocket does not have...
Most certainly it is quite different than an OEM (or SE) comp, but it basically and simply provides some shock relief that my current solid sprocket does not have have. As such, my solid front sprocket is a little noisy.
Also, I know several people who have put a solid front sprocket on an OEM HD bottom end.... something I wouldn't do. I would be less adverse to that, with the Man O War and it's limited cushioning
That's why I think of the Man O War as in between a solid sprocket and a comp... But yes, if I had to list it in one of those two categories. I would call it a solid sprocket.
The Man O War was just announced when I got my solid front sprocket. I often wish I had waited a bit to see how it performed before getting the one I have now. While some people have reported they thought the Man O War was noisy, most reports I have read don't make that claim...
So far, my Vulcan solid front sprocket isn't annoying enough that I want to spend the extra money to replace it with a Man O War...
You used a Vulcan sprocket on one of your builds?
Hell if it fits...it's probably as well made as anything....
Speaking of which, Dark Horse Crankworks are very well respected (their products) as you well know. That's a very important thing to consider when putting together an expensive build.
Man O War works great, I love mine, but there's a couple of things you have to check. You need to check for excessive runout and you have to check alignment. If either of those things are off you will end up with noise, not to mention potential issues for sure down the road.
Checking runout and alignment only makes sense. Kinda like the S&S gear drive cams. Many people don't check the backlash when doing the install of gear drive cams, then complain they are noisy..
I used a Vulcan kit that included a 32 tooth front sprocket (instead of OEM 34 tooth) and a proper sized manual primary chain tensioner, instead of requiring a shoe that fits on the OEM tensioner. It's a little noisy, but other than that, I like it. It's on my bagger with a 124" S&S engine, so I'm not worried about crank issues.
I am well aware of the Hoban Brothers and Dark Horse Crankworks. Their work and reputation are very well respected by people in the know. A good friend who used to race Harleys in the early to mid 1980s, had all his engines worked on by the Hoban Brothers.
I have a MOW compensator (actually called a motorsprocket) on the FB along with the Hayden chain tensioner. Works great for the last few years. On the RK, the second SE style compensator is beginning to give up the ghost at 60K.
Since I am replacing the inner primary race/bearing/seal, I just ordered a MOW motorsprocket along with the infamous shifter lever seal...
Anyone got more than 50000 anyone the after market stuff?
