Code P1356
Old Sep 12, 2023 | 07:25 AM
Madd Max's Avatar
Madd Max
I have always run ngk dcpr7eix iridiums. I did put 6r12 back in to see, still did the same thing. I like the ngks better.
Old Sep 12, 2023 | 09:16 AM
Highway Handler's Avatar
Highway Handler
Originally Posted by Lonewolf176
Stock plugs?
“I put new plugs and new wires on it already.”
Says he changed them.
Old Sep 12, 2023 | 09:21 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Went as far as stating he tried the OEM plugs and NGK plugs and still got the error.
Old Sep 12, 2023 | 09:23 AM
Germansheperd's Avatar
Germansheperd
Originally Posted by Madd Max
Hello,
I have a 15 Streetglide Special and I’m getting code P1356. Bike runs fine, but when I stop at a destination come out and start bike it’s in limp mode. I take off and after a mile or so it clears up goes back to normal. I have changed plugs and wires and checked all connections that I could and nothing seems to be loose or disconnected. Could it be coil, fuel filter?
what coil? Stock OE, aftermarket? Put a new stock Harley coil on it.
Old Sep 13, 2023 | 07:49 AM
Vernal's Avatar
Vernal
With Ion Sense OEM plugs and wires are required, see note on first page. Did I read you had different plugs?
Old Sep 13, 2023 | 09:24 AM
hattitude's Avatar
hattitude
OP.... You said you put on "new plugs and wires"....
Then you mentioned you used NGK dcpr7eix iridiums, but replaced them with OEM and still had the problem...
Did you replace the wires with OEM wires.... or aftermarket...?
Old Sep 13, 2023 | 02:24 PM
Madd Max's Avatar
Madd Max
Yes stock wires. The coil is the original stock coil. I have been working long hours this week, but coil and injectors will be the next thing I check when I get a chance.
Old Sep 16, 2023 | 10:46 PM
Madd Max's Avatar
Madd Max
I put a new coil on it, still doing same thing. Bike starts fine take a ride, stop for a few minutes, go to start it up and it is in limp mode. Ride it about a mile it clears up. Tomorrow I will pull tank and check injectors and connections.
Old Sep 17, 2023 | 04:42 PM
Madd Max's Avatar
Madd Max
I pulled tank and checked all connections under talk. I unplugged the injectors, and swaped holes to see if it would make a difference. Went for a nice long ride bike ran flawless. I came back home let it sit for about 20mins, went to start it, would not start, just spins over. No codes thrown. I also bought a new lithium battery.
Old Sep 17, 2023 | 04:48 PM
Madd Max's Avatar
Madd Max
Would a bad stator act like that?
