Code P1356
Old Sep 11, 2023 | 08:05 AM
Madd Max's Avatar
Madd Max
Default Code P1356
Hello,
I have a 15 Streetglide Special and I’m getting code P1356. Bike runs fine, but when I stop at a destination come out and start bike it’s in limp mode. I take off and after a mile or so it clears up goes back to normal. I have changed plugs and wires and checked all connections that I could and nothing seems to be loose or disconnected. Could it be coil, fuel filter?
Old Sep 11, 2023 | 08:27 AM
hattitude's Avatar
hattitude
I would think fuel would affect both cylinders, unless you have a fuel injector issue...
Bring an inline spark tester with you and when it goes into limp mode, see if you are getting spark to the rear cylinder.... If not, time to play with the multi-meter and check the coil and coil to ECM connections.
If you are getting spark, then inspect the connections to the rear fuel injector closely, and pull out the multi-meter or a noid light to test power to the fuel injector.
Old Sep 11, 2023 | 08:32 AM
Musician's Avatar
Musician
What mileage is on the bike? When was the filter changed last? Coils generally either work or don't work, nothing in between. If a manual is available, look for that code, it should steer in the right direction. I don't have mine at hand.
Old Sep 11, 2023 | 08:34 AM
hattitude's Avatar
hattitude
P1356 Rear Cylinder No Combustion
Old Sep 11, 2023 | 09:57 AM
Madd Max's Avatar
Madd Max
It only has 16,000 miles on it, I never changed the fuel filter. It has me scratching my head as to why it only does it intermittently and not all the time.
Old Sep 11, 2023 | 10:32 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Perhaps many things cause no combustion on the rear cylinder. This guy had quite a repair for his P1356 code.
P1356 No Combustion rear cylinder - Harley Davidson Forums (hdforums.com)
You can hope that it is a loose spark plug lead or spark plug screw cap if your plugs have them. That would be a very cheap result.
Old Sep 11, 2023 | 10:33 AM
hattitude's Avatar
hattitude
That wouldn't be unusual with an electrical problem... Dirty/corroded connectors, loose/worn/broken wires, etc. can cause intermittent contacts... Some electrical sensors will have intermittent issues, especially when they get hot, before failing altogether...
Old Sep 11, 2023 | 10:48 AM
memphisharley's Avatar
memphisharley
do you have a tuning device on the bike.
Old Sep 11, 2023 | 11:21 AM
Madd Max's Avatar
Madd Max
Yes, Power Vision.
Old Sep 11, 2023 | 12:00 PM
TriGeezer's Avatar
TriGeezer
Yes, Power Vision.
Well, then…the first thing I’d do is remove that.
