How to determine voltage issue
Old Oct 1, 2023 | 09:48 AM
lvbred's Avatar
lvbred
1st Gear
Default How to determine voltage issue
I have a 2008 Streetglide that I recently replaced the battery. I've replaced the battery multiple times but this time I'm noticing that my voltage meter isn't acting correctly. When I turn on the bike the voltage meter shows 0 but when I start the bike it creeps up to 16-18v, then it bounces around sometimes going back to 0. I went on a 2 hour ride yesterday with this happening and every time I started the bike the voltage showed 0 then creeped back up. I've checked the battery connections and made sure everything is correctly connected. I'm confused on where I should start troubleshooting this issue so has anyone else had the same problem?
Old Oct 1, 2023 | 09:54 AM
HD_noobie's Avatar
HD_noobie
Check with a decent voltmeter. Kinda sounds like a bad gauge.
The bike wouldn't start if the voltage was 0.
Old Oct 1, 2023 | 10:01 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
On the other hand going passed 15 volts is also bad and possibly signifies a bad connection to the battery. The battery is itself an excellent regulator to hold the voltage steady.
Old Oct 1, 2023 | 10:19 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Congratulations on your first post to HDF, to the Forum.
1. Make sure your battery is fully charged.
2. Get your battery load tested at a local parts store to ensure it is a good battery.
3. Go here for troubleshooting guidance instead of guessing:
https://www.hdforums.com/forum/elect...sting-1-a.html
https://www.hdforums.com/forum/elect...sting-2-a.html
Report back on what you find out.
Old Oct 1, 2023 | 11:02 AM
QC's Avatar
QC
If you are using the voltage meter in the fairing to get these readings, get a real voltmeter to determine if it is accurate before trying to diagnose.
But an initial impression would be a faulty voltage regulator.
You'll need a good volt meter to diagnose correctly.
Old Oct 1, 2023 | 01:47 PM
albebaubles's Avatar
albebaubles
100%. Just replaced the voltage regulator in little brother's '19 ultra -- it was acting similarly.
socobandit
May 21, 2022 06:14 PM
tsmithopt
Oct 9, 2019 01:44 PM
richard567
EVO
Aug 23, 2016 06:59 PM
taterbum
Electrical/Lighting/Alarm
May 9, 2015 10:57 AM
rsnky
Oct 22, 2006 06:09 PM
