1999 Roadking
Old Nov 9, 2023 | 08:04 PM
  #31
pennafxu's Avatar
pennafxu
Default O2 sensors
This new map required O2 sensors, so I welded 18x1.5 bungs on front and rear exhaust 3-6” from the exhaust header. Per Zippers manual. The O2 sensors plugged in and were connected to the ecu.
O2 sensor
Front plug
Old Nov 9, 2023 | 08:07 PM
  #32
pennafxu's Avatar
pennafxu
Default Oil cooler
Ultra cool 😎
What a PIA that was to install
New oil filter
Old Nov 9, 2023 | 08:11 PM
  #33
pennafxu's Avatar
pennafxu
Default Rocker arms
Unboxing
Shaft
Bushings
Pushrod end
Roller/valve end
Old Nov 9, 2023 | 08:48 PM
  #34
gonemad's Avatar
gonemad
Nice looking Benchmade auto you got there. And looks like you actually use it. This thread just keeps getting better.
Old Nov 9, 2023 | 09:09 PM
  #35
pennafxu's Avatar
pennafxu
Thanks... Yeah my son got it for me 10 years ago or so. It was a special edition, called the Infidel (he got a black one). Luckily in KY you can conceal carry this type of blade. I have abused the crap out of it through the years and he gives me hell for it! However, the blade is razor sharp as he has a special tool sharpening system and is always finding any excuse to sharpen our knives.
Old Nov 10, 2023 | 07:06 PM
  #36
pennafxu's Avatar
pennafxu
So I took off the rocker arm support plates after finding TDCC for each cylinder
Old Nov 11, 2023 | 12:32 AM
  #37
pennafxu's Avatar
pennafxu
You can see the pressure off the valve stem...
Plate removed
TDCC
No gap
Gap
Old Nov 11, 2023 | 12:36 AM
  #38
pennafxu's Avatar
pennafxu
Onto shaft removal
On the bench
bolts are different. They will not be reused
Needed to tap out shafts
some purchase
1 down, 3 to go
Old Nov 11, 2023 | 12:40 AM
  #39
pennafxu's Avatar
pennafxu
measurements
snap gauges
mic'd bushing diameter
shaft diameter
difference, which was in spec.
Old Nov 11, 2023 | 12:44 AM
  #40
pennafxu's Avatar
pennafxu
Removed parts... only the plates to be reused after cleaning
plate
rocker arms and shafts
