Melted sleeve on pipe 🤦🏼‍♂️
Old Dec 7, 2023 | 08:20 PM
Strtbobber1's Avatar
Strtbobber1
Default Melted sleeve on pipe 🤦🏼‍♂️
I melted the sleeve of my hoodie to my pipe today. I'd like to hear some good ways to clean it off with scratching the pipe to $hit. Thanks!
Old Dec 7, 2023 | 08:58 PM
MotoJockey's Avatar
MotoJockey
I've heard a REAL 100% copper penny, Easy-Off Oven Cleaner, "0000" steel wool and WD-40, aluminum foil and WD-40 or Coke Cola......... YouTube may have even more tho.
Old Dec 7, 2023 | 09:58 PM
im's Avatar
im
What exactly would be pipe?
A slip on muffler?
A shield?
A head pipe?
Chrome or black?
Old Dec 7, 2023 | 10:17 PM
Strtbobber1
A slip on muffler?
A shield?
A head pipe?
Chrome or black?
Chrome shield about 8" after rear cylinder.
Old Dec 7, 2023 | 11:00 PM
rizzo's Avatar
rizzo
A pic would help.
I'd start with a plastic razor blade or light switch cover, the plastic is soft and won't scratch the steel, gently scrape as much off as you can. After that I go to GOOP hand cleaner, again not a harsh chemical but very effective at softening things without being destructive. I use this approach at the shop to bring old, vintage used parts back to life without causing damage life harsher chemicals can, Rubbing alcohol is another safer solvent. I stay away from using something that you have to rub as an abrasive on the surface. Worst case scenario, replace the chrome heat shield.
Old Dec 8, 2023 | 04:20 AM
Bayou FLHR-M8-128"'s Avatar
Bayou FLHR-M8-128"
Take bike for a good ride, so it is good and hot.
Then as soon as she is parked, pull oil dipstick and use the hot oil and a soft rag.
Had wife's melted boot on my shovelhead pipes for months and discovered this when I accidentally dropped oil on hot pipe.
Old Dec 8, 2023 | 04:24 AM
kojak's Avatar
kojak
if it’s more than a small spot, I wouldn’t bother. Take off heat shields are dime a dozen online. Just replace it.
Old Dec 8, 2023 | 04:47 AM
PeterB's Avatar
PeterB
Get it hot and hit it with spray can oven cleaner, the non-abrasive type. Gets heavy baked-on grease etc off, but not sure about hoodie sleeves. That's a new one on me.
Old Dec 8, 2023 | 07:42 AM
BareKnuckle's Avatar
BareKnuckle
Nevr-Dull does wonders for shyte like that.
I used it for melted on riding boot heel.
Old Dec 8, 2023 | 08:24 AM
RKZen's Avatar
RKZen
Weren't you going to replace your exhaust?
Seriously, I've use the copper penny (don't use a newer one) and WD-40 trick on melted rain gear. No copper penny, use a plastic paint scraper.
