These threads go off track quickly sometimes.
Yes it will void your warranty. Do not drill out the Cat, that's a waste of time. Cut it out properly or don't mess with it.
Why is the drilling out of the cat a waste of time?? I picked up a used (virtually brand new) take-off head pipe on-line...they're readily available and dirt cheap.
Ran a drill bit through it to get most everything cleaned out. Used an old screwdriver to knock out the remaining "big" pieces. After that, I ran an old cylinder hone through it to really clean it up and make it look like it came without a cat stock.
All in, it took me less than an hour. Swapped out the head pipe and I'm happy...as is my wife with the reduction in heat. Bonus...I have my stock head pipe with cat intact...just in case.
Just a public service message, and somebody with more knowledge please chime in as I could be wrong, but I read somewhere that the heavy metals in the CAT are extreemly carsonogenic and the dust should never be inhaled. Be sure to wear a good mask when reaming your CAT.
If you want a nice job, just cut the pipe in half at the cat, pull it out and weld it back up. Don't forget to mark the pipe before you cut. I did that took to a weld shop and they welded it back up for 20 bucks. Open up the A/C also big sucker are nice, then tune the bike, if you don't tune it will still run lean. My bike ran cooler as far as power not much more.
I have removed the cat on two headers by the drill method. To each his own but why go to the extra trouble to cut it open then re weld when can be drilled out in an hour or less.
Can't be. Otherwise Marifornians would have posters of dying children and dead cows warning us about those converters.
There are platinum group heavy metals (Palladium, Platinum and Rhodium) that are toxic but probably worse there are Refractory Ceramic Fibers. Think "asbestosis" only with ceramics when drilling out a converter without protection. What's fun is now studies are finding those metals in the environment from converters... I predict that greenies' heads will explode when their noses are rubbed in it.
Also does anyone did it without removal of the headed or this is rather not doable?
If I can avoid welding and removal from the bike it would be my ideal solution but not sure if I am not asking too much.
It is easy to remove the cat WITHOUT removing the head pipe and also no need to cut n weld to get everything out. Just use a big drill bit and drill around the edge as many times as needed then use a big screwdriver or similar to knock off any remaining pieces... I did mine in about 20-30 min after getting the slip-on off
Ok, I hesitated to bring this up because it will probably start a frenzy of posts on the subject but I would remove the head pipe to take out the cat... Think about this a minute.. When you drill or bust out the cat, notice all the cat dust floating around? Ever think about the fact that the exhaust valves are open on at least one cylinder? Also not so much with a stock cam, but there is overlap where both intake and exhaust valves are open at the same time. There is also reversion where exhaust gas reenters the cylinder through the exhaust valves.. So you knock the cat out, make all this dust and small chunks of cat, maybe think you got it all out and then crank the engine.... Does the engine ingest some of the dust and small chunks?? It might or might not but why chance it?
