2022 RKS - Quick question. I would like to save some $$$ and decat my OEM header rather than buying new one since I plan to save my stock shields anyway no need for me to spend $800 on fullsac.
Will overall final effect on performance of the bike be significantly different between using decatted OEM header vs expensive FullSac?
I run KhromeWerks mufflers
It might sound stupid but at the end of the day both options are hollow pipes so I would expect final effect on performance gains (when installing cams) would be negligible if any. Is my logic tinted?
Any idea?
I have a friend who tunes for a living (Sheffer Performance in Evansville, IN). He has many builds out there, including 124/128's using the OEM decatted head pipe. With a good supporting cast of parts, the torque curves look great and the builds do not bottleneck in any way. He could have made more money off me, and some friends by recommending some other head pipe he distributes for, but said the decatted OEM unit will work great. And it did/does.
I'm not sure if you've done this yet. I drilled mine out on my 20 SG. I took the head pipe off. It's a little more work, but makes it a lot easier to work on and 100% worth it to remove first. Cutting and welding is not necessary. Drilling it out took about 30 minutes, and it was a complete removal. I drilled two holes about 3/4" apart and used a wrench to put inside the holes and twisted the whole thing out. Easy enough, and I've done it again since.
You will not see a performance increase, but it was recommended to get a tune. It does change the way the engine runs. Personally, I don't feel like it's worth the trouble. I just replaced the system and didn't look back. If you're keeping the 2 into 2 look, then it's worth the effort to set yourself up for better running down the road with the tune.
Ok, I hesitated to bring this up because it will probably start a frenzy of posts on the subject but I would remove the head pipe to take out the cat... Think about this a minute.. When you drill or bust out the cat, notice all the cat dust floating around? Ever think about the fact that the exhaust valves are open on at least one cylinder? Also not so much with a stock cam, but there is overlap where both intake and exhaust valves are open at the same time. There is also reversion where exhaust gas reenters the cylinder through the exhaust valves.. So you knock the cat out, make all this dust and small chunks of cat, maybe think you got it all out and then crank the engine.... Does the engine ingest some of the dust and small chunks?? It might or might not but why chance it?
I used a shop vac with a vinyl tube adapted to the hose to remove the dust and fragments after removing the cat.
21505513[/url]]I'm not sure if you've done this yet. I drilled mine out on my 20 SG. I took the head pipe off. It's a little more work, but makes it a lot easier to work on and 100% worth it to remove first. Cutting and welding is not necessary. Drilling it out took about 30 minutes, and it was a complete removal. I drilled two holes about 3/4" apart and used a wrench to put inside the holes and twisted the whole thing out. Easy enough, and I've done it again since.
What drill bits and what wrench do you have that will reach all the way in there?
I would recommend putting a tuner on your bike after a decatting.
Why? Catalytic converters have zero impact on performance or sound despite all the hen talk?
Really want to hear why in all seriousness.
My take has always been, if you can sport for a 30k PLUS motorcycle, you can afford to spend for a proper header that doesnt have a catalytic converter. If not, performance mods are not in your wheelhouse. Just ride the bike.
Happy New Year to all!
The honeycomb type cat's used today despite looking restrictive actually flow very well, the main reason many remove them is when carrying a passenger they feel excess heat on their right leg on warmer days.
