LONG crank when cold.
Old Mar 7, 2024 | 05:02 AM
  #31
702's Avatar
702
Originally Posted by krustuhfar
UPDATE: pulled plugs today, they are white. Lean?
Probably just real old, but could also be caused by water in your fuel. Because you have no history on this bike, just put new plugs in it and see what happens. It will either get better or it won't. If it's not better, then you can let the guessing game resume. Another bit of advice, don't let your head swim in the bullshit that a couple of people have tossed at your issue. They do that in almost every post here. Clear your head, put in new plugs, start over.
Old Mar 7, 2024 | 06:18 AM
  #32
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
the engine is heavily modified from what I understand, bored out to 103. Has bigger cams also, And power commander.
That certainly changes things.
I strongly agree with the suggestions of new plugs, regardless of when you replaced them.
Without pictures, I can't say if the plug is lean or not. Sure, it sorta sounds it, but it could be interpretation.
The Power Commander is a crude way of making the bike run rich. Which it kinda sounds like yours isn't. They can also be a source of problems. On a more stock engine I'd say just pull it and see if that solves the problem. With a modified engine, I'd do the same, but with caution. Probably just a few cold starts to see of those are improved. I doubt they will be, but perhaps.
As the bike is modified, and has some questionable characteristics, you may want to ask around about someone who can dyno tune. Just something to consider.
I know you've said it's modified, do you have documentation of those modifications, or is it just stuff you were told?
Old Mar 7, 2024 | 06:53 AM
  #33
Rounders's Avatar
Rounders
H. I recently purchased a 2007 Electra Glide Twin cam.
good.
How recent is recent and did it ever start good?
If it ran good for awhilw, than I am not sure I would pursue dyno or tuning. Problem with canned maps is you don't know what you got.
If it never ran good, than who knows. But was it starting cold fine before. Plugs are cheap, and one of the no skill things I usually throw at problems. But I have never had it solve a problem on a 4 stroke.
Making sure the power commander is in tight and pins look clean is good idea. But it runs after it starts. Guessing from a million miles away I would guess spark. I have seen bikes struggle with spark. But once running you never know it is missing or off a little.
Also you are letting it fully pressurize and fuel pump start and turn off, before trying to start? It is easy to rush this.
Old Mar 7, 2024 | 07:12 AM
  #34
im's Avatar
im
It would seem like some information was not available when originally posted.
Based on:
"the engine is heavily modified from what I understand, bored out to 103. Has bigger cams also, And power commander."
At this point it would be best to gather your information.
Detail exactly what bike changes exist outside of factory stock.
Heavily modified means different things to different people.
Diagnosis without knowing details can lead you to wasted time and money.
Old Mar 7, 2024 | 08:53 AM
  #35
krustuhfar's Avatar
krustuhfar
6th Gear
Default Update #2
I believe I’ve found the issue.
Plugs were pretty worn. They were white, which I know is an indication of running lean. Or could it just be that they are really old? They were Harley plugs, and the exposed parts of the plugs were also quite rusty.
Bought some generic Autolite brand copper plugs from the part store, they were $3 a piece I figured what the hell let’s try it out. I know mine are bad.
Bike started right up on cold this time…
Now I’m not sure if I should start another thread on this, but, was copper the right choice? I have the 96ci twin cam, bored to 103, bigger cams, and power commander. Should I have gone with iridium? I’m seeing mixed answers everywhere. Some swear by the copper due to it being higher compression.
Old Mar 7, 2024 | 09:18 AM
  #36
Tom H's Avatar
Tom H
Copper is fine. I'm not big on Autolite. Iridium just lasts longer. I would suggest getting the correct Harley brand plugs for your bike so your sure to have the correct resistance in the plug. Champion also makes the plug, someone will post the number I'm sure.
Good luck,
Tom
Old Mar 7, 2024 | 09:26 AM
  #37
don67's Avatar
don67
Boosting Post #8 - Check battery strength before doing anything else.
Same thing happened to a previous Yamaha - long cold crank followed by sputtering start - fixed after an hour on a smart charger.
Old Mar 7, 2024 | 09:37 AM
  #38
memphisharley's Avatar
memphisharley
Good luck,
Tom
Champion Copper Plus Plug Number RA8HC Spark Plug - 810
Part # 810
I have never ran these tho.
Old Mar 7, 2024 | 10:08 AM
  #39
Jackie Paper's Avatar
Jackie Paper
Put a set of the Harley branded plugs in it. Yes, Harley doesn't make them but there low resistance plugs special for your ion spark detection system that the coil reads and relays to the ECM .
Glad you got it fixed but you need to protect it on hills, hard throttle or getting more gear then motor likes .
If you get them, check the resistance and compare them to what you put in and report back to us as a favor for all the hard work we do on here
I do get paid 24/7 but I need better note .
Old Mar 7, 2024 | 11:52 AM
  #40
Rounders's Avatar
Rounders
Glad I was wrong with it being the plugs. Nice and easy
