Twist Grip Sensor Reset
Old Mar 22, 2024 | 12:12 PM
Buelligan666's Avatar
Buelligan666
Why did you change the throttle control? Your cruise control light is on all the time? Even when you turn the cruise off?
Old Mar 22, 2024 | 12:50 PM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by downzero
Before I replaced the sensor, I had to roll the throttle forward quite a bit to cancel. Now, even 1/8" or maybe less cancels it. It's so sensitive that if you have the throttle open 1/4 of the way and set the cruise and let the sensor snap back to idle, it'll cancel the cruise control.
I know on the throttle grip on my ‘20 Heritage, all it takes is a fraction of an inch forward to disengage cruise control. I just got back from a ride and I tested it because of this thread. I’ll have to take my ‘14 UL for a ride and see how it responds. I don’t really remember how it responds because I’m old and scatterbrained.😵‍💫
Old Mar 22, 2024 | 02:07 PM
downzero's Avatar
downzero
I had some issues with chafed wires on a set of bars I built, so I built an entirely separate set to replace them so I can dig into the other ones without the bike being down. Suggestion for all of you reading this: carefully use thin heat shrink on any internally wired handlebar, and use a dremel tool to de-bur every hole they pass through no matter who made the bars. Hard and expensive lesson to learn for me; fortunately it happened at home and I wasn't left stranded.
And no, the cruise light isn't on with the switch off, but of course I never turn it off either.
Old Mar 22, 2024 | 02:15 PM
Buelligan666
Gotcha. People drop their bars off at my house. I extend their wiring and install the controls on their new bars for them. I'm also an electrician by trade. Fishing wires is second nature for me. Sorry to here about your issues. Sounds like you could get by with using the Namz till you fix your other sensor. Sounds like the aftermarket hasn't nailed the twist grip sensor yet.
Old Mar 22, 2024 | 03:40 PM
downzero's Avatar
downzero
Yeah, I may return them.
I've been doing wiring for a long time, but I foolishly believed a youtube video I watched where the guy said he hadn't had any issues with chafing. I didn't have the same experience.
Old Mar 24, 2024 | 09:33 AM
downzero's Avatar
downzero
Just as an update, I reinstalled my H-D sensor yesterday. I'm going to return the Namz one. Their tech support suggested I send it back to them to test it. All symptoms resolved.
Old Mar 25, 2024 | 12:36 PM
downzero's Avatar
downzero
Well, I lied. All but one. Sometimes the CC doesn't want to engage after a shift, but if I wait a few more seconds and hit the button again, it does. I hope I didn't introduce another gremlin, but once it does work, if I cancel it and hit set or resume again, it comes right back, it's just a matter of getting it initially set after a shift.
Old Mar 25, 2024 | 02:28 PM
Ultra103's Avatar
Ultra103
Spray some cleaner like DeOxit in the clutch switch, sounds like it may be getting a tad sticky. May not be the issue, but it couldn't hurt.
Old Jul 10, 2024 | 01:11 PM
feeserb's Avatar
feeserb
Stage I
Default Same issue with cruise blinking.
Hello i have the same issue with the namz sensor. Seems like sensor does not stop on zero. Cruise light flashes as soon as it is in idle position. Everytime I apply throttle and leave off it changes the rear cylinder cutout. Did you end up sending yours back? Thanks, Brian
tensaw
Feb 26, 2018 07:26 AM
Lone Dawg
Aug 14, 2016 11:11 AM
nemick
Aug 28, 2014 07:43 AM
Bano
Jan 13, 2014 10:36 PM
roadslide
Jan 7, 2011 04:30 PM
