Bike Shutting Off While Riding
Old Jun 19, 2024 | 07:12 PM
N1265's Avatar
N1265
Default Bike Shutting Off While Riding
Hi Guys,
Had an issue today with my 2011 FLHTK shutting off while going down the road, This has never hapend before and I am wanting to know where to start looking to find the cause of this problem.
Here is what happened :
I have been riding bike into work as usual with no issues, but the last couple of days we have seen temps in the mid 90's. Today after sitting in the sun for about 8 hrs. I got about 10 miles down the road and the bike just shut off , I was running 60 MPH in 6th gear with the cruise control on like I normally do and just lost power to the bike. Radio , cruise control light, 6th gear lite, all dead with motor not running. I put it in neutral but no "N" indicator lite came on. It did let me put the flashers on and I costed to a safe place to pull over. I then turned the ignition switch off and just sat there for 5 minutes . when I turned the ignition switch back on everything powered up as normal and the bike started as usual. I adjusted the vents on the faring to get air flow over the engine and ran the bike as normal for 20 miles till I hit my driveway.
and Ideas of what might have happend and where to look ? The bike is a 2011 Ultra Classic with the 103 and 65k miles.
Many Thanks,
Old Jun 19, 2024 | 07:18 PM
Rounders's Avatar
Rounders
If the flashers worked, I would think main fuse, ignition witch and battery cables are good. Always good to tighten battery cables, cause free and easy. But I doubt you would have been able to restart if loose.
Check codes?
What is interesting is lights go out, so that is more than ignition system cutting out. That makes me think maybe loose connection.
Old Jun 19, 2024 | 08:53 PM
YZR's Avatar
YZR
Battery
Old Jun 20, 2024 | 05:38 AM
16Bullitt's Avatar
16Bullitt
Check the battery cable connections. I've had the positive side come loose twice
Old Jun 20, 2024 | 06:07 AM
Gunnysgt's Avatar
Gunnysgt
True, When I was working at a Harley Dealer Service writer it was not uncommon for folks to come in that simply had battery cables come loose. Usually it was the negative but could be either. Start there.
Old Jun 20, 2024 | 07:50 AM
Germansheperd's Avatar
Germansheperd
Originally Posted by N1265
Hi Guys,
Many Thanks,
Check cables and codes
Old Jun 20, 2024 | 08:38 AM
Mr. Mike's Avatar
Mr. Mike
Your story is mine. Short answer; “Check the battery’s mfg date”.
Old Jun 20, 2024 | 08:50 AM
Steelernation's Avatar
Steelernation
Have a friend with the same bike same symptoms. Broken wire at the connector behind the air cleaner. The connector turns a hard 90 degree and pulls on the wires.
Old Jun 20, 2024 | 12:17 PM
memphisharley's Avatar
memphisharley
what he^ said...start the bike and wiggle the wires at the at the connector by the air cleaner to see if it stumbles.
Old Jun 20, 2024 | 05:26 PM
N1265's Avatar
N1265
Many Thanks for all the advice, I won't have time to dig into it until the weekend but will report back when I find something .
