Baggers....how many tools do you carry?
Old Sep 3, 2007 | 10:02 PM
Casper's Avatar
Casper
Default RE: Baggers....how many tools do you carry?
Depends on where I'm going, ie short trip just the HD kit and a cell phone ( friends are great). Long trip, I pull a trailer so I have a Sears tool bag and carry sockets, wrenches (both metric and standard for sockets and wrenches) allen kit, both std & met, screwdrivers, zip ties, electrical tape, fuses (both sizes) mutli meter and test light, assorted other might need items...also found some tape that tightens as you put it on, can repair a leaking radator hose...cool....you can buy a lot of the items needed at sears in the companion line, not as expensive as Craftsman, but will do in a pinch, plus if you loose one, easy to replace...
Always carry a cell phone and have some type of roadside service, either HOG, AMA or through your insurance company...
Old Sep 3, 2007 | 10:10 PM
RIDEIRISH's Avatar
RIDEIRISH
I pay the Snap-On guy to follow me whenever I'm headin' out...lol
The HD kit, the Craftsman Kit w/ zip ties, electrical tape, wire, an extendable mirror to look under & behind places....a few extra bolts, nuts, fasteners...
Old Sep 3, 2007 | 10:58 PM
blfrgrkcustom's Avatar
blfrgrkcustom
None. That is what I pay AAA too much money for. Road side assitance and do good maintenance checks before each trip.
Old Sep 3, 2007 | 11:28 PM
Rodent's Avatar
Rodent
I carry the tool kit that came with my bike, along with a few other essentials, which all fit nicely (minus fluids) in a military tool pouch I purchased at the local Army/Navy surplus store.
TOOLS:
T-27 Torx tip
T-55 Torx tip
3/8” drive Ratchet
3/8” drive, 3” extension 3/8” drive, 6” extension
3/8” drive sockets: 12 point 10mm socket
3/8”, 7/16”, 1/2", 9/16”, 5/8”, 3/4"
HD 8in1 screwdriver (2 phillips, 2 flat, 4 torx)
3/8” allen wrench for transmission fill plug
Assorted allen wrenches
End Wrenches: 12 pt. 10mm
3/8”, 5/8”, 3/4", 7/16”, 1/2", 9/16”
Snap ring pliers
1 small vise grip pliers
1 small channel lock pliers
8” Crescent wrench
Oil filter wrench
FLUIDS:
2 Quarts oil
1 Quart transmission fluid
1 Bottle Brake fluid
MISC:
Bungee chords
Die-Electric grease
Drive belt repair kit
Duct tape
Electrical tape
Flashlight
Heim joint for shifter linkage. (Known to break frequently)
Jumper cables
Kick stand pad
Maxi Fuse & misc. fuses
Notepad and pen
Pocket size electrical meter
Shop towel
Siphon hose
Small first aid kit
Small tow strap/rope
Spark plugs & gap gauge
Tire repair and inflation kit
Tire gauge
Turn signal & taillight bulbs
Valve stem tool
Zip ties
Old Sep 4, 2007 | 12:50 AM
ironspirit_3's Avatar
ironspirit_3
Have a kit from "CruzTools". Hope I don't jack myself up.... but it's all my friends who use it. I usually check and double check my bike before a ride. Especially a 4500 to 6500 mile ride to make sure all is well with my '05 RK.
Old Sep 4, 2007 | 01:03 AM
SoCalRyder's Avatar
SoCalRyder
I carry the essentials that will get me home 99.9% of the time.A Cruz-Tools Econo Kit for Harley Davidson (link below), with some extras toolsthat I thought the tool kit was missing, needle nose pliers, a 3.8 ratchet and a couple sizes of 3/8 extensions . I installed an HD accessory plug (P/N 91843-970,$17.95) to run an air compressor (or anything else that runs off a cigarette liter socket, like a cell phone charger). A 12V air compressor from Pep Boys (with flashing safety light), $19.95, a new tire repair kit (both my front and rear rims are solid, so I could plug a tire to get home), a quart of oil, a cell phone and a AAA membership (for catastrophic failure).
If I had a front rim with spokes and a tube tire I would also carry a couple of small tire irons and a patch kit and a scissor jack.
I put this combination of tools together to get me home on rides within 100 miles of my home.If I were going further, I would probably throw in a scissor jack, along with afew more selected tools, wrenches,sockets, hammer, etc.
http://www.rbcomponents.com/02/cruz-...-davidson.html
Old Sep 4, 2007 | 05:09 AM
xxxflhrci's Avatar
xxxflhrci
I carry about 15 lbs, including a small pump and an emergency belt.
Old Sep 4, 2007 | 05:11 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: blfrgrkcustom
Good luck with that plan. I rarely go on a long trip to where I don't break out the tool kit to adjust this or tighten that.
Old Sep 4, 2007 | 06:41 AM
ceng's Avatar
ceng
4th Gear
I use H-D kit, cell phone, and a 45 auto or a 44 mag.
Old Sep 4, 2007 | 07:11 AM
Garemlin's Avatar
Garemlin
I was amazed the first time I needed to break out the HD tool kit that it didn't come with something so simple as a phillips screwdriver to take off the seat. Needless to say I threw one in the pack when I got home.
