Partially Solved: Oil Leak
Old Jan 29, 2025 | 04:18 PM
  #31
paulhog's Avatar
paulhog
Originally Posted by jake24lt
Shifter shaft seal?
That's a good thought. I'll check that out. Thanks!
Old Jan 29, 2025 | 04:42 PM
  #32
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Flex seal
Old Jan 29, 2025 | 07:36 PM
  #33
oldnslow's Avatar
oldnslow
looks like shifter shaft seal, This is what I run, Engine oil in the engine, Belray in the primary, it's RED, Royal Purple in the transmission, Its purple,
Oil leak brown, engine leak, is it Red, primary, is it purple Transmission, Kind of narrows it down
Old Jan 29, 2025 | 11:29 PM
  #34
paulhog's Avatar
paulhog
Originally Posted by BrandonSmith
Flex seal
Don’t tempt me. 😂
Old Jan 30, 2025 | 02:34 AM
  #35
BrandonSmith
Originally Posted by paulhog
Don’t tempt me. 😂
Old Feb 13, 2025 | 03:33 PM
  #36
paulhog's Avatar
paulhog
I guess I'm going to have to take this to a shop. I can't figure it out. I've got the bike parked level now (jiffy stand on a 2x4) and it still pools up the same way. I haven't started it for over a week and it still leaks the same amount.
Old Feb 13, 2025 | 06:17 PM
  #37
BRKLYN1955's Avatar
BRKLYN1955
Either missing or crushed like mine were two weeks ago. Oil filter didn’t bring one, found myself darting out to hardware store bought several, they didn’t hug collar of bolt slightly big but time will tell. I gotta order me a bag full, the primary is soon, gotta borrow a jack here in Caribbean.
Old Feb 20, 2025 | 10:56 AM
  #38
paulhog's Avatar
paulhog
Update: This is looking more like a shift shaft seal. I don't have the tools or the time to do it myself. I'm taking it to a local indy shop. They quoted me about $550 parts and labor. Since the primary needs to come off, I'm having all seals and gaskets replaced. Bike has about 70,000 miles, so it makes sense to do it while it's all torn apart. I don't get much riding time lately and most of my free time is four wheeling and hiking with my wife and dog, so I'm considering selling the bike after this season. I don't want to sell it with a leak, so fixing it is the right thing to do for the next possible owner. Bike goes in on Monday. I should have it back on Friday. I'll keep you posted. Thanks for all the advice.
Old Feb 25, 2025 | 08:31 AM
  #39
paulhog's Avatar
paulhog
Confirmed! Shift shaft seal. Thanks again to all that offered suggestions. Very helpful! Inspection of the primary revealed there's probably about 50% wear on the cam chain tensioner and some slight wear on the compensator. Overall, everything looks pretty good. I might not have it back in time to ride this weekend.
Old Feb 27, 2025 | 10:39 AM
  #40
Mongo1958's Avatar
Mongo1958
Darn! Then the hunt goes on. It started after my cam upgrade. It's real clean oil that's leaking. I'd bring it back to the shop where the work was done, but I've moved out of state. Thanks for your input.
Get some purple power or a good degreaser, and spray it all over the bottom of the engine.
Clean it good and use a leaf blower to dry it off.
Then take it for a short ride and inspect it again. You will find the leak.
