Spark plug choices
Old Feb 26, 2025 | 10:58 PM
Jerrysprinting's Avatar
Jerrysprinting
6th Gear
Default Spark plug choices
Hello, I have the 2003 Road king CVO. In the manual, it states that only the recommended spark plug should be used. When this book was written I don't think they had the variety of plugs that we have today. Has anyone used the E3 plugs in their older twin cam bikes? And with what results?
I would like to try them, but also like to follow MFG recommendations.
Old Feb 27, 2025 | 02:37 AM
kdawggy's Avatar
kdawggy
Stage I
Easy enough to just try some. I have just put in IXU22 Iridiums. In other bikes I have found the iridiums offer superior acceleration smoothness and a slight improvement in fuel economy.
Old Feb 27, 2025 | 05:36 AM
jake24lt's Avatar
jake24lt
Twin cams use ion sensing, for anti knock strategy. Save yourself the aggravation and put the stock plugs in it. The plugs Harley specs, work the way the system was designed. Adding boutique plugs that are mostly snake oil ,will not do anything any better than what Harley put in the bike.Its been running for what, 22years?
Old Feb 27, 2025 | 05:38 AM
jake24lt's Avatar
jake24lt
The only thing superior, is you wallet gets lighter.
Old Feb 27, 2025 | 05:43 AM
Buelligan666's Avatar
Buelligan666
Stock plugs. Everything else is BS.
Old Feb 27, 2025 | 05:50 AM
MURPHCC1's Avatar
MURPHCC1
Stock plugs......E3 is a scam
Old Feb 27, 2025 | 06:41 AM
702's Avatar
702
The only thing E3 is good at is marketing. They do an excellent job of turning normally intelligent people into suckers. Don't be one.
Old Feb 27, 2025 | 06:44 AM
eighteight's Avatar
eighteight
More HP !
Better MPG !
Be more popular with women !
Old Feb 27, 2025 | 07:30 AM
Kenny94945's Avatar
Kenny94945
I recall Utube - The Farm Project - has tested E3 and all types of spark plugs.
Good luck with your decision.
FWIW
Copper plugs flow electricity the best, yet have the shortest life.
Since Harley plugs are typically easy to remove, I always go with copper.
Multiple electrodes, well, see Farm Project or other.
Heat range, air fuel ratio (ie plug reading) could be considered more important than plug design.
Old Feb 27, 2025 | 09:14 AM
hattitude's Avatar
hattitude
Originally Posted by Kenny94945
FWIW
The Harley 6R12 plugs (#32362-04, formerly #32317-86A) will do everything you need on a street driven motorcycle....
If you don't have a dealer near by, use Champion Copper Plus RA8HC plugs.
That Champion plug is not an equivalent plug, it is the exact same plug as the 6R12. Champion makes (unless there was a recent change) the 6R12 plugs for Harley, and the RA8HC is their version of the same plug.
IMHO... With the ease of plug changes on the Twin Cams, and the low cost of the 6R12 or Champion RA8HC plugs, there really is no reason to look elsewhere...
You can get plugs of exotic metals that will last longer, and plugs with revolutionary designs that will cost more, but you won't find a plug that runs any better than the 6R12 or Champion RA8HC.
And yes, they both work well with the Harley ION Sensing knock detection system.
FWIW.... The 124" S&S crate engine for my '16 Bagger (135HP & 151TQ) came with Champion RA8HC plugs...
