Won't start
Old Apr 16, 2025 | 02:45 PM
Wyoming adam's Avatar
Wyoming adam
2nd Gear
Default Won't start
Starting issues. 2012 FLHTK. Turn on ignition oil pressure light comes on. Nothing else. No lights radio etc. switch is on. No cranking radio. Nothing but oil pressure light. All other readout is dead. any ideas? New battery installed last summer. Heated garage storage.
Old Apr 16, 2025 | 02:57 PM
chopper_man's Avatar
chopper_man
Doesn't matter the battery was installed last year. Needs to be load tested.
Old Apr 16, 2025 | 04:05 PM
btsom's Avatar
btsom
All winter, even in a heated garage, is a long time for a battery to sit and not be on a maintainer. You probably have a clock, security, and perhaps other "keep alive" memories that slowly, but constantly drain the battery.
Old Apr 16, 2025 | 07:43 PM
BRKLYN1955's Avatar
BRKLYN1955
Could it be a fuse of some kind? In my case mine started but I had no neutral light no gas gauge and no speedometer, it was a fuse.
Old Apr 16, 2025 | 10:00 PM
Rounders's Avatar
Rounders
It was running last year? Put on charger or jump pack and see if any other lights come on. Its odd nothing else came on. Maybe other lights come off BCM? Does it have BCM?
Was it on charger? If not just put on charger over night.
Old Apr 17, 2025 | 07:29 AM
KK0G's Avatar
KK0G
The very first step is to check the battery voltage with a voltmeter. Until we have that basic information anything we tell you is just a wild guess.
Old Apr 17, 2025 | 11:36 AM
Wyoming adam
2nd Gear
Default Thanks.
FOLLOW UP- Battery was shot. Yes it was on trickle all winter. That's what kinda threw me. Thanks for the input guys. Much appreciated
Old Apr 17, 2025 | 01:12 PM
GalvTexGuy's Avatar
GalvTexGuy
What do you mean by “trickle”. Which one?
Old Apr 17, 2025 | 01:24 PM
Wyoming adam
2nd Gear
4 amp trickle charger. I know it works because I just used it on my truck after I left my lights on overnight
Old Apr 17, 2025 | 02:46 PM
GalvTexGuy's Avatar
GalvTexGuy
If I were you, I think I would switch your bike to a battery maintainer like
this one this one
. That trickle charger is probably what killed your battery.
