Belt culprit
Old Jul 1, 2025 | 03:04 PM
BRKLYN1955's Avatar
BRKLYN1955
Default Belt culprit
Hello again, after play with compensator springs, ordering stock one the to findout it's Screamin Eagle upgrade. My final drive belt is my problem slippage causing the chain noise in primary. Who from or where would I get 137T belt? Recommendation would be appreciated.
Old Jul 1, 2025 | 03:22 PM
MURPHCC1's Avatar
MURPHCC1
Are you saying your final drive belt is slipping? The one from the trans to the rear pulley?
Are you sure?
Is it missing teeth?
Old Jul 1, 2025 | 09:14 PM
BRKLYN1955's Avatar
BRKLYN1955
Yes
Old Jul 2, 2025 | 05:00 AM
eighteight's Avatar
eighteight
I`d buy the OE belt ( $266.99 here)
Both the factory parts list and Dennis Kirk show your bike to be 139T
Not 137T
The H-D p/n is 40024-97
Old Jul 2, 2025 | 05:56 AM
Screamin beagle's Avatar
Screamin beagle
Another vote for the factory/ OEM belt. Not a job you want to do again because you saved 20 bucks at Billy-bob's Cheap-*** Belt Company lol...you know the saying...buy once cry once.
Old Jul 2, 2025 | 09:25 AM
hattitude's Avatar
hattitude
If your drive belt is/was slipping that badly, you should inspect both the trans pulley and the rear wheel pulley. I would suspect that one or both may need replacement too.
The Harley OEM belts are one of the things that HD does well. I would replace with OEM like others have suggested.
Old Jul 2, 2025 | 09:43 AM
MURPHCC1's Avatar
MURPHCC1
Def OEM belt and NEW pulleys.......been there.
Old Jul 3, 2025 | 06:02 PM
Sparkules's Avatar
Sparkules
OEM belt and make sure you don’t kink it while handling for install, the instructions warn against folding it below a certain radius to prevent damaging it.
Old Jul 3, 2025 | 09:00 PM
BRKLYN1955's Avatar
BRKLYN1955
new pulleys? Is it a must?
Old Jul 3, 2025 | 10:22 PM
Goose_NC's Avatar
Goose_NC
Highly recommended to change pulleys when changing high mileage belts. Other than that, a good inspection of the pulleys will tell you what you need.
