Brake caliper issue
Old Aug 19, 2025 | 03:45 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Ultra103
It's certainly possible to mess just about anything up on a motorcycle. The part that gets me is when people open the package, throw the instructions away, beat the thing into place with the heavy end of an adjustable wrench, then go nuts about how the product is 'useless junk' when it fails.
Yeah for sure, but in this case (cheapo installers), you want to throw the instructions away
Old Aug 19, 2025 | 04:32 PM
Diesel X's Avatar
Diesel X
Started to do this myself and buy the tools but for what cheap tools and parts would cost, I said screw it and let the dealer do it. I normally do all my own work on my bike. If it happens again I'll buy some good tools and do it myself.
Old Aug 20, 2025 | 07:08 AM
Notgrownup's Avatar
Notgrownup
With newer bikes I just about want to change the bearings almost at every tire change.
Old Aug 20, 2025 | 11:39 AM
Max Headflow's Avatar
Max Headflow
Sounds like some here need to go to therapy.. I've installed bearing wrong to the point where they died in a 1000 miles and figured out that most installers suck. I've got 60K on a 17RK with the original bearings. I've over 50K on a 07 EGC front without changing.. The 07 has a later front wheel with 6205s. The concern, I have about replacing bearing so often is that the press fit will eventually be lost..
Old Aug 20, 2025 | 01:21 PM
hardheaded's Avatar
hardheaded
The dealer installed my 2nd set of bearings that were under warranty incorrectly. Left slop between the inner space and bearing.
I found this when i bought the tool and replaced them myself again.
When i found this i took the wheel back to the dealer and the service writer said that's how the new bikes are. Buy the tool and install yourself and you will know they are done correctly.
Don't trust the dealer to do it right !
Old Aug 20, 2025 | 01:40 PM
Notgrownup's Avatar
Notgrownup
My 07 I sold to a friend has 125000 miles on it and it’s on the 2nd bearing.
Old Aug 20, 2025 | 01:43 PM
Notgrownup's Avatar
Notgrownup
Old Aug 20, 2025 | 02:16 PM
Max Headflow
Nothing wrong with the center spacer being loose enough to move.. The 6205-c3 bearings have around 0.005-0.006" axial play.
Now if there was say 0.020" of clearance there would be an issue.. How much was there? Which install tools did you use?
Old Aug 20, 2025 | 02:19 PM
Ultra103's Avatar
Ultra103
Shouldn't matter how cheap an installer tool is, it's the tool holding the tool that controls the depth.
As Max said above, you want a 'little' slack in the spacer tube, just enough to be able to move it around, but not enough to have any gaps. Too loose or too tight and you'll overheat the bearing, the grease turns to magic smoke.
Old Aug 20, 2025 | 02:42 PM
Max Headflow
If they are like these, they can axial load and destroy the bearing..
https://www.hdforums.com/forum/touri...l#post21852139
Further up the page, the Jim's are machined flat.. Some of his early ones weren't You can cut clearance between the inner and outer race but both the inner and outer have to be at the same level.
