Check engine light
Old Jan 7, 2026 | 09:39 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
What did you use to clean the IAC with? Hopefully it wasn't Carb Cleaner!
Old Jan 8, 2026 | 07:47 AM
Max Headflow's Avatar
Max Headflow
An 11 touring bike is fly by wire. Uses a servo controlled throttle blade.. No IAC.
Old Jan 8, 2026 | 11:53 AM
JordanJim's Avatar
JordanJim
no IAC on 2011 trouing bikes. But I cleaned it map cleaner
Old Jan 16, 2026 | 09:35 PM
Highwaymans's Avatar
Highwaymans
Personally Id always replace sensors with OEM on everything I own. That aside Id be checking ground, 5v reference and output signal with a vacuum pump attached and voltmeter with sensor connector connected before throwing a new sensor at it. Those check out at sensor connector, Id backprobe the ECM connector checking output signal at the ECM itself.
Timincols614
Jun 10, 2025 04:55 PM
Riffraff123
Electrical/Lighting/Alarm
Apr 2, 2020 07:49 PM
Gatorok
2014-2024 Touring Models
25
Oct 13, 2016 12:01 AM
shooter5502
Jun 13, 2010 10:50 PM
shooter5502
Jun 13, 2010 11:27 AM
