Are there any manufacturer numbers to identify this air jack? I already have the J&S jack and the air seems like a nice upgrade. Apparently, the "Strongway 5-ton air/hydraulic bottle jack " is not longer available. Looking via google initially only shows 20t versions now.
The only numbers I can find are SBT170402313. Those are on the foot pump linkage assembly. Also the patent #5.341.723. Hopefully you will have better luck than me locating a similar jack. If you find one let me know.
Actually this one looks similar to the one I have. Not sure if it has the same vertical release which is really nice to have. https://www.google.com/aclk?sa=L&ai=...BAgJEDE&adurl=
Rob..the second lowest setting..with the cross bar underneath the slots. Again, I’ve used it a lot, but I’m always suspicious of the mechanical stops being partially blocked by the cross brace underneath.
I can't picture what you're referring to when you wrote: "with the cross bar underneath the slots".. My J&S has two safety locks, one on each side. There are 5 "holes" or stop positions for each safety lever to lock into. That's basically it.
I will say that the J&S's design moves the cycle's full weight directly over center as it raises higher. So the higher you raise it up the MORE stable the jack is, especially IF you plan on moving it around under load. (I always raise it up to either the highest or second highest position for safe maneuvering around my garage.)
Right there Rob..Im wondering if your jack is different than mine. I bought mine in 2012.
I just bought a fellow members jack. I dont have it in my possession yet, but from the pictures in this thread, the picture of mine and other pictures Ive seen, theyre all the same. Apparently, it hasnt been a problem.
THANKS for the picture....now I know what you're referring to.
Mine is exactly the same as your pictures show. Although I typically don't leave it stopped in that #2 hole position, I don't see a safety issue IF you prefer to leave it there. If, you check underneath one of the holes to see how much of the "safety stop bar" protrudes when placed in one of those hole positions, I think you'll agree that only a fraction of the safety bars protrudes below the hole.....and the cross bar is welded far enough below the holes to allow the bar to lock...same as it does in the other holes.
As I mentioned before, The BEST position for maximum stability is the highest or second highest lift position. The jack's design moves the weight up and over center the higher the lift raises up. So, I strongly suggest you use one of the two highest lift positions all the time. Other than that, bleed the system (yearly) ...but also shoot some grease in the grease fittings on all of the wheels.
