07' is KILLING ME SLOWLY....
Old Sep 13, 2007 | 06:33 PM
  #31
easyglider's Avatar
easyglider
Default RE: 07' is KILLING ME SLOWLY....
Keep takin it back .After a few times start talkin about lemon laws and I bet they fix your **** then.
Old Sep 13, 2007 | 06:38 PM
  #32
spizzyman's Avatar
spizzyman
[sm=WTFsgign.gif]Man, I sure see a lot of complaints on the 07s and now 08s. If this keeps up there will be a lot of inventory to choose from in a few months.
spiz
Old Sep 13, 2007 | 06:52 PM
  #33
BOARGAURD's Avatar
BOARGAURD
They did change the tranny and there are internal oil lines now.
Old Sep 13, 2007 | 07:13 PM
  #34
racklefratz's Avatar
racklefratz
ORIGINAL: spizzyman
spiz
OUCH! Mine's one of the '08s. Stay tuned.
Old Sep 13, 2007 | 07:51 PM
  #35
07ultrachuck's Avatar
07ultrachuck
Well cam plate didn't work now have to order oil pump.
Asked if they Harley would like to buy back not much of a response!
  #36
Fishpart's Avatar
Fishpart
14,000 miles I have the same sepping from tranny. Other then that no other issues.
Old Sep 13, 2007 | 07:54 PM
  #37
07ultrachuck
Also was told when ordered cam plate that they had pump in stock
now no pump in stock have to order three to four days. Bike has been in shop 1 month today should i be p..... off or what?
Old Sep 13, 2007 | 08:09 PM
  #38
straggler's Avatar
straggler
ORIGINAL: hunt4570
Damn...My '07 RG(4000 mi) engine is clean as a wistle(ok some bug guts),no whine in 5th,no biggie on the heat deal,normal motor noises..same ones as in my '99 RKC ...hopefully it stays that way.
Me too, 07 EG no problems whatsoever. A fine machine.
Old Sep 13, 2007 | 09:14 PM
  #39
Arizona's Avatar
Arizona
One tip I'll give you guys - DO NOT OVERFILL the tranny - even by an ounce or two. I've found that my bike has this same seepage and a small drip under it if I put more than 22 ounces in the tranny. Once I went from 24 to 22 ounces no more leak. I'd had the tranny/shaft seal replaced thinking it was worn but still leaked. Had them redo it and it still leaked. Then I reduced the amount of tranny oil (still on the dipstick properly) and now no more leak/drip...
Just my experience.
Old Sep 13, 2007 | 09:25 PM
  #40
MarkThomas's Avatar
MarkThomas
I came VERY close to buying a new '07 RKC...glad I went with a used '06 instead (thanks, HDForums!)
Even though I have an '06, I am thinking maybe an extended warranty is in order...is this something I can get??
