Am finding things about Tmax.....
Old Sep 11, 2007 | 06:45 PM
shortleg's Avatar
shortleg
Default Am finding things about Tmax.....
I found out about the cutting off of fuel on decel setting.
Oh man did that make things great.
Funny I never thought about tuneing this much untill
I could do it.
Shortleg[Dave]
Old Sep 11, 2007 | 06:54 PM
streetglide007's Avatar
streetglide007
Default RE: Am finding things about Tmax.....
Does this replace that annoying popping with the Jake brake sound? I'm having a T-max installed tomorrow and am learning more from forums than anywere else!
Old Sep 11, 2007 | 08:35 PM
shortleg's Avatar
shortleg
Yes it will,other members told me about it.
You will find it under module configeration,then basic
settings.
There you will be able to turn it on and adjust between what
RPMs the fuel is cutoff.
Shortleg[Dave]
Old Sep 12, 2007 | 12:30 PM
hambone's Avatar
hambone
Is the Tmax the same as a PCIII or VH FuelPak?
[/align]
Old Sep 12, 2007 | 12:55 PM
glens's Avatar
glens
Latter are units that piggy-back the stock ECU and modify its output.
Former is complete replacement for stock ECU.
Old Sep 12, 2007 | 12:58 PM
hambone's Avatar
hambone
Ahhhhhhh. Well since I'm looking to go from my carbed herigage to the injected Street Glide, I think a litte more research is needed on my part.
Thanks for the info.
[/align]
Old Sep 12, 2007 | 01:03 PM
Akitakoi's Avatar
Akitakoi
Is that something new or is it under one of the options?
[IMG]local://upfiles/16250/90B55AA26D9B4104867145787EA09431.jpg[/IMG]
Old Sep 12, 2007 | 01:18 PM
SIM's Avatar
SIM
Hammy, look into either the T-max or the DTT if you want to save money in the long run. If you are only going to put something on to help with heat go for the PCIII.
Old Sep 12, 2007 | 01:24 PM
hambone's Avatar
hambone
ORIGINAL: simcom
$hit now there's a DTT??? Oh my head is spinning![&:]
Well the plan for now, once I actually buy the bike, is to just put a set of the black ceramic true duals from Vance and Hines (not avail til Nov) with one of the high flow filter kits. Was going to go with the PCIII till I read this thread.
Oh, and after my waranty is over I'm going to go to the GMR Performance 107" kit. http://gmrperformance.com/Twin_Cam_P...e_Packages.htm [/align]
Old Sep 12, 2007 | 01:42 PM
SIM's Avatar
SIM
what model glide you gettin'? 08? if so, the units are not out yet. NONE of them
