cruise control
Old Sep 17, 2007 | 08:18 AM
rude king's Avatar
rude king
Stage IV
Default cruise control
Changed out the handle bars on the bike getting ready for trip out west, got the new ones on and went for test ride now the cruise will not lock up red light comes on but no green light any sugestions other than to the dealer leave on trip next monday.
Old Sep 17, 2007 | 08:30 AM
SIM's Avatar
SIM
Default RE: cruise control
Check for a pinched wire going to the housing. Sounds like it is not making contact/grounding.
Old Sep 17, 2007 | 08:44 AM
LeadDoggy's Avatar
LeadDoggy
Double check all wires for handle bars. Maybe wire came loose. Also check to be sure that all wires are tight into the connectors....
Old Sep 17, 2007 | 09:08 AM
jskwarek's Avatar
jskwarek
Check the two wires up next to the frame that plug into the throttle cable make sure they are in the correct spot, then go through the reset procedure. This happened to me when I put my apes on and I reversed these two wires and went through the cable slack reset procedure and all was ok after that.
Jeff
Old Sep 17, 2007 | 09:40 AM
EvilDave's Avatar
EvilDave
Had the same problem when I changed bars, the fix was to redo the lash adjustments. Throttle cables when moved changed the position of the roll off switch and could not get the lash adjustment to work until I did a complete cable adjustment.
Old Sep 17, 2007 | 09:44 AM
jskwarek's Avatar
jskwarek
Lash Adjustment that is what it is called. Thanks EvilDave I couldn't think of the term off the top of my head, was having one of those brain fart moments.
Jeff
USMC6112
Jun 23, 2017 09:24 PM
HonorGuard
Jun 4, 2014 04:00 PM
towncountry
Aug 7, 2012 08:03 PM
honda236
Jun 29, 2010 11:02 PM
csarquilla
Jul 7, 2008 10:38 PM
