No More ECM Flash
ps.. just to make the lawyers and peddlers office happy.... the above stated comment is purely of my own opinion based on years experience in the auto repair field, and does not imply its the opinion of others on this board. Take it as you will. thank you!
some recalibrations for certian setups are only for 05 and back. The htcc manifold is an example not sure if they make adiffernt htcc manifold for an 06 and newer. They may of been confused on what you were asking for. now if they were confused i would make sure i was nto calling it the wrong thing. i would ask for a "stage 1 recalibration flash for the ecm."
if they are still confused or try the sert sale i would find a different dealer. I think a sert is a better deal but, they should advice you and not lie to you.
Well peddler, flawed as in, only partially able to do its job. They have 2 O2 sensors that can kind of do their job, and an ecm, as of 07 that can kind of manage fuel trim on its own, but relies heavily on pre-programmed mapping. There is systems that can rectify the lean running condition on the bikes, and allow adaptive learn like modern cars do. So yeah, its pretty much a flawed design!lol You have a SERT, you paid how much for it? if you bought it at the dealer, you paid in the range of high $400s for it, or if you went to CHi town harley etc, you got it for $364~. Your dealer talk to you about doing a dyno run on the bike? Add that up with the cost of the sert, which all on earth it is, is a security key to let you into the ecm software, and downloads to flash it, and your in the range of a Tmax or DTT. As for which is better, SERT or aftermarket ecm, or a piggyback system, well do the searching on that, youll form your own opinion.
It is your opinion that the MoCo should have designed the ECM differently. Great, we welcome opinions here. But your statement that the stock ECM is "flawed as in, only partially able to do its job." is factually incorrect. The stock ECM is doing exactly the job it was designed to do.
The dealer told you the truth.
If you add pipes then you need another download because it will run even leaner and the Dealer does not support it.
[sm=deadhorse.gif]
Ill say this much before it turns into a pissing contest. The ecm from harley does what they want it to do, does it do the job as well as it should? I dont think so, so as such I believe its flawed. Ford built Pintos in the 70s with the design of a fuel tank subject to catching fire during rear end collisions. Thats how they designed it, so therefore its not flawed then right? If one wants to use the sert, more power to them, but why pad Harleys pocket on it, knowing they could very well created the market for the need of a sert. Money spent for dynos and a sert, you can get something else that will bring the benefit of EFI to your bike via true adaptive learn technology.
[sm=deadhorse.gif]
Look it up in the parts book. The "stage one" that HD will do is an air cleaner ONLY, they have NO download for air cleaner and pipes.
The ECU has sufficient auto-tuning and does a remarkable job. If you don't like it, replace it.
All right, no more complaints from me. I let you know what happens.
Blueroad
