Belt adjustment
Old Sep 25, 2007 | 09:25 PM
harleyrobert4's Avatar
harleyrobert4
Default Belt adjustment
Does the bike need to be on a lift/standto adjust the belt or can it be on the jiffy stand? I cannot find anywhere in the 07 manual where it specifies a requirement. My other question is, if I have my 36mm wrench on theleft (welded ) side, whattool do you use to hold the right (clip side)?
Old Sep 25, 2007 | 09:32 PM
Jim Dawson's Avatar
Jim Dawson
Default RE: Belt adjustment
I don't know about the '07 models but my '08 manual says to check it with 10 psi in the shocks and on the jiffy stand. 3/8-7/16" deflection with 10 pounds force applied at the midpoint of the bottom belt strand.
Old Sep 25, 2007 | 09:38 PM
tlb's Avatar
tlb
I know on a 06 fatboy you do it with the bike upright without anyone sitting on it. I read a post before about the wrench needed. I hate to be one of those guys but try a search on the rear axle. they wear talking about wear to buy the proper wrench.
Old Sep 25, 2007 | 09:42 PM
harleyrobert4
thanks for the replies. I already have done a searchand have bought the36mm socket, but do I need a stand or can I do it on the jiffy stand?
Old Sep 25, 2007 | 10:23 PM
Drum's Avatar
Drum
I adjusted mine on the jiffy stand. Then I checked it upright and it was good.
Old Sep 25, 2007 | 10:50 PM
glens's Avatar
glens
Page 2-93
"Motorcycle upright with rear wheel in the air or on jiffy stand without rider or luggage."
3/8" - 7/16" deflection except for the short-shock bikes which spec 1/4" - 5/16"
Old Sep 25, 2007 | 11:44 PM
SoCalRyder's Avatar
SoCalRyder
Glens quoted the manual.
Old Sep 25, 2007 | 11:46 PM
dawg's Avatar
dawg
ORIGINAL: j2dawson
pre tell, where did you find an 08 service manual? Or is this in the owner manual
Old Sep 26, 2007 | 08:25 AM
NICK56's Avatar
NICK56
i always did it on a bike lift... the mcy comes with thewrench .. unless u never got it. . + u dont need to hold or secure the other side of the axel..
ps: the tension is not THAT critical.. Make it tight not too tight.. Ive owned many HD's since the early 80'S all berlt drives..Never any issues..
Old Sep 26, 2007 | 08:41 AM
EZ2Rider's Avatar
EZ2Rider
Here is an earlier thread on belt adjustment.
https://www.hdforums.com/m_2231619/tm.htm
I cannot get anyone who seems to know if, in the 06 service manual, the instruction to adjust the belt, "at the loosest point" is a misprint and dealer says he sees many overtightened belts. It will whine if too tight and can cause premature wear and, apparently, bearing wear. Anybody have REAL info on this. Do they really mean to adjust at the TIGHTEST POINT? Would seem right to me. I am now just adjusting on the sidestand per the manual but to 1/2 " at the TIGHTEST POINT and it seems to work fine. No whine but pretty taught when warmed up.
EZ
markkoby
Jan 2, 2013 08:54 PM
PLEIKU69
Jul 8, 2012 10:42 AM
freebyrd
Jun 22, 2009 12:27 PM
YellowHawk
Nov 3, 2008 03:11 PM
cdestuck
Sep 16, 2008 04:10 PM
