Road King Custom Front lowering ? HELP
Rico
According to my math the 21 raises it anywhere form 1.5-2". I have not lowered the rear but plan on progressive 440 on the rear about 1/2" shorter. My main concern is clearence and the pvc spacers that come with the kit.
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
130/90-16 4.6in 12.6in 25.2in 79.2in 800 0.0%
90/90-21 3.2in 13.7in 27.4in 86.0in 737 8.6%
so going with the 21 gives you a 1.1 inch larger radius, and almost a 10% difference on your speedo. i guess if you want it to be the same height as before, then you should go with a 1 inch spacer..... (disclaimer: i am not an expert,
nor did i stay at a holiday inn express last night)
btw, i have done the progressive 440 11-1/2 inch on the rear on my road king custom. no change to
the front. you will lose some ground clearance with those shocks. i did not notice any adverse
handling characteristics, but i was able to flat foot better...
overall, i like the shocks, but i don't know that i would have spent 500 bucks for them. i had them leftover from my sporty (figure that one out, they recommend the same shock for the sporty and the road king, weird huh?) so gave them a try. maybe if i ever win the lottery, i would get a set of works shocks custom built for me.....
http://groups.msn.com/toddsharleypix...eforkswap.msnw
http://hotrodsbikeworks.com/tech/040...ork_component/
