Derby Cover
Old Oct 7, 2007 | 05:02 PM
drdiesel1's Avatar
drdiesel1
Default RE: Derby Cover
ORIGINAL: Ultrasweet
Maybe we need to use some antiseize compound on them. T
How do you spell antisieze anyway?
What`s needed is a high quality torq`s bit. The K-Mart tools cause bigger problems than they are worth.
I use Snap-On tools (because I was a tech for 30 years) and never have problems with removing fastener like this. It`s when the cheap tool rounds off and damages the bolt that all the problems start..
Old Oct 7, 2007 | 05:03 PM
SpikeUK's Avatar
SpikeUK
Tip: If you don't have an impact driver.... before attempting toundo the screws, give each one a hard tap with a small pin punch, then use a decent quality T27 Torx driver. Works for me !
Old Oct 7, 2007 | 07:01 PM
brinks13081's Avatar
brinks13081
Mission acomplished, it wasn't pretty but I finally got it off.
Old Oct 7, 2007 | 07:30 PM
drdiesel1's Avatar
drdiesel1
Well lets here it. What method worked. Did you destroy the cover/primary or just figure out how to do it without canabulism...........
Pics would be better than a narrator IMHO.......
Old Oct 7, 2007 | 07:35 PM
brinks13081
I drilled the screw a bit and then jammed an ez out in there and was finally able to turn it out with some ancient tool my dad had, I was really starting to stress over it.
Old Oct 7, 2007 | 10:12 PM
drdiesel1's Avatar
drdiesel1
Thanks Hannibal....J/K...Glad you got it handled.
Old Oct 7, 2007 | 11:01 PM
choochoo's Avatar
choochoo
T27 tork bit.
Try using a screwdriver type driver handle. Rap it a couple times with a hammer as you twist to unscrew. Helps break the "set" of the screw from the hot / cold cycles.
You might try doing the same thing with a tight fitting allen wrench (you already stripped it). soetimes it will re-bite just enough to loosen it.
If not you will need to drill out center of screw and use an easy out extractor.
Old Oct 8, 2007 | 07:55 AM
skratch's Avatar
skratch
when you go to put it all back together, use a bit of anti sieze on the bolts. and don't just use your calibrated elbow to tighten them back up. use a torque wrench, next time, you'll be glad you did.
Old Oct 8, 2007 | 09:55 AM
gman's Avatar
gman
BTW, go to ACE Hardware and get chrom allen head bolts and replace them junk torx bolts. Next time will be a breeze with the new bolts.
nuttbaggerr
Mar 20, 2020 08:02 AM
COZWV
2014-2024 Touring Models
15
Apr 4, 2015 06:17 PM
DaveNBPT
General Topics/Tech Tips
24
Oct 20, 2014 10:11 AM
VVS
Sep 25, 2014 07:53 AM
Fupl18
Jan 8, 2009 04:33 PM
