Difference of inner fairing shape on 2008
Old Oct 10, 2007 | 09:00 PM
mhutch2's Avatar
mhutch2
Default Difference of inner fairing shape on 2008
I need your collective wisdom to answer something my dealer doesn't have an answer for. I'm planning on painting the inner fairing on my 02 Ultra. I picked up a used inner fairing to have prepainted so I won't have any downtime. I studied the "new" fairing very carefully and it looks identical to the one on my bike. All the holes are in the same place, all the curves and shapes appear to match. I got a wild idea and checked the back for a part number and found 58 497-08A. I called the dealer and had him look it up to see if it shows what it fits. Turns out it fits all 2008 FL models (Electra and street glides). He says I need 58 497-96A which is for 97-07 FL. When I asked him what was different about the two he says "no idea, won't fit".
Any of you know what is different? Help?
Old Oct 10, 2007 | 09:16 PM
Jim Dawson's Avatar
Jim Dawson
Default RE: Difference of inner fairing shape on 2008
One difference is that the '08 has an extra mounting hole on each side for mounting the new adjustable "Willie Wings". Other than that I don't know.
Old Oct 11, 2007 | 09:08 AM
EvilDave's Avatar
EvilDave
No hole for throttle cables on 08 since it is throttle by wire, but that should be an easy fix.
[IMG]local://upfiles/29973/D5F84C5DE73148DEB16C59AA27912BEE.jpg[/IMG]
Old Oct 11, 2007 | 11:26 AM
extech's Avatar
extech
These two guys have answered your question. Them are the only differences.
Old Oct 11, 2007 | 02:04 PM
mhutch2's Avatar
mhutch2
Thanks for your responses. Here's what a different dealer says. "The only differences are that the 08 will have a different bolt pattern for the side deflectors and no hole for the throttle cable - biggest difference is that the holes for the speedo and tach gauges are bigger".
Anyone ever heard of that? Anyway, looks like I have an inner fairing that fits an 08 FL - for sale.
Old Oct 11, 2007 | 02:10 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: mhutch2
The bolt pattern for the deflectors is the same except the '08 has an extra bolt hole at the top. Seceral guys ahve installed the new deflectors on the older fairings either by using only three bolts each or drilling another hole and using a bolt and nut for the top one.
Old Oct 11, 2007 | 09:02 PM
crosbycourt's Avatar
crosbycourt
Stage II
Old Nov 28, 2007 | 11:20 AM
leohd's Avatar
leohd
the gasket sizes on the speedo and tach are same part# anybody know for sure if speedo and tach sizes are different from 2008 and earlier? I am having same issue have a 2008 inner fairing and want to use it on a 2003
oldbie
Feb 25, 2017 02:49 PM
steelerdude1
Nov 23, 2012 02:43 PM
meanjean
Jun 2, 2010 09:45 PM
SBJJC
Touring Parts
Mar 20, 2010 11:09 AM
omgtkk
Apr 3, 2009 08:41 PM
