Need Help
Old Oct 14, 2007 | 06:07 PM
Bondsman's Avatar
Bondsman
6th Gear
Default Need Help
I have an 07 SG with approx 3200 miles on it. I am a reader of the forums and do not post any at all. Mainly because I am very happy with my bike and have not had any problems. At the 1000 mile checkup I added Rinehart true-duals, Stage II breather, PCIII and a Sundowner seat. My problem is with my left pipe, the one from the rear cylinder. There is about an 1/8 gap between the end cap and the muffler. The other side cap is seated flush with the muffler. The left sidehas an exhaust leak between the end cap and the muffler to a point where it is turning the writing (etching) brown. How do I need to handle this complaint? I have sent BUB an email but have not heard from them in over a week. Anyone with the same problem find a solution? All suggestions will be appreciated.
Old Oct 15, 2007 | 12:56 AM
PapaTravis's Avatar
PapaTravis
Default RE: Need Help
Well, from all I have read, that brown (soon to be purple) end cap is a deisgn flaw. That is if we are talking about the same thing. I have read a ton of posts where guys have complained about this. I also read that rinehart will replace them. I do not know if that is true, just what I have read. I would continue to email them, and if you can find a number, give them a call. IMO.
BTW, it is good to read someone that is happy with their ride.
Old Oct 15, 2007 | 01:22 AM
SoCal_Pappy's Avatar
SoCal_Pappy
The End Cap is Loose..... CALL CUSTOMER SERVICE @ BUB... They'll handle it... Just make sure they send you a NEW END CAP...
Phone: 877 BUB PIPE (877-282-7473)
Old Oct 15, 2007 | 08:48 AM
Bondsman's Avatar
Bondsman
6th Gear
That is what I was looking for (phone number). Appreciate the help.
Old Oct 15, 2007 | 11:38 AM
glide's Avatar
glide
Have you tried loosening the bolts that hold the cap on and see if it will move closer to the muffler?
Old Oct 15, 2007 | 11:42 AM
FLHT's Avatar
FLHT
ORIGINAL: glide
And if that doesn't work maybe the muffler is drilled wrong.
Old Oct 15, 2007 | 02:28 PM
Bondsman's Avatar
Bondsman
6th Gear
Talked to the rep in customer service at BUB. I am sending a copy of my purchase invoice to him, and he will be sending me the newer teflon coated end caps. When they arrive I will look at it closer to make sure that they seat to the end of the muffler before I run them. You may be right the muffler may be mis-drilled, if so I will bring that to their attention and see if it can be rectified. Thanks again, great place for questions and answers.
Old Oct 15, 2007 | 03:02 PM
FLHT's Avatar
FLHT
You need to know when my tips started to turn purple, instead of sending me just the tips they sent me all new slip ons because they have made a design change to the baffles also
Old Oct 15, 2007 | 03:11 PM
extech's Avatar
extech
Purple end cap...flaw?
More like "nature of the beast"
Do they actually warranty for a purple end cap?
Old Oct 15, 2007 | 03:38 PM
FLHT's Avatar
FLHT
ORIGINAL: extech
They sure do. They say they have corrected the problem and I have a pair of the new and improved but I didnt put them on. I have replaced mine with a pair that Eastern Performance makes.
