Diagnostic Mode
Old Oct 24, 2007 | 06:37 PM
gregm's Avatar
gregm
Default Diagnostic Mode
'05 EGC. I filled it up yesterday and apparently hit the button/switches in a secret sequence that made the bike go into a diagnostic mode. I think I turned on the ignition switch while I was holding in the trip meter reset button.The gauges lit up and the speedo display started showing all kinds of stuff that I could scroll though with the turn signal switch. I turned the ignition switch off then back on and all was O.K. I looked through the H.D.shop manual when I got home but there was no info on what happened. Anybody know what happened & how I may be able to use it in the future? Where can I get info on the diagnostics?
Gregm
Old Oct 24, 2007 | 06:50 PM
twincam47's Avatar
twincam47
Default RE: Diagnostic Mode
ORIGINAL: gregm
Gregm
There is separate manual called Electrical Diagnostics for your 2005 it is part# 99497-05. It tells you how to extract trouble codes, the code information from both the ECM and TSM/TSSM and all other electrical information.
Old Oct 24, 2007 | 08:07 PM
skratch's Avatar
skratch
https://www.hdforums.com/m_1337101/tm.htm
check this thread out for some info....
Old Oct 24, 2007 | 09:08 PM
twincam47's Avatar
twincam47
ORIGINAL: skratch
the procedure has changed....the information on the posted thread does not work on a 2005. For 2005 the codes are displayed in the odometer window.
Old Oct 24, 2007 | 10:42 PM
gregm's Avatar
gregm
Thanks Bros. I'll be orderingthe manualtomorrow.
Gregm
Old Oct 25, 2007 | 04:34 AM
skratch's Avatar
skratch
ORIGINAL: twincam47
ORIGINAL: skratch
oops, sorry, wrong thread. i was looking for this one:
https://www.hdforums.com/m_43975/tm.htm
this i have verified on my 07 and it works, but good to have the manual to make sure that they have not changed the meaning of the code displayed (dont know why they would do that though)
i had a hard time finding it, i have it printed out and in my file cabinet.
Old Oct 25, 2007 | 09:30 AM
gregm's Avatar
gregm
Thanks Skratch, that looks just like the little bit I saw before I turned the ignition off. Great thread.
Gregm
JJustice97
May 13, 2017 11:55 AM
DPete
Nov 12, 2011 03:07 PM
Gonzy
Jun 21, 2011 03:18 PM
iflyguns
Mar 7, 2010 09:20 AM
firespy999
Sep 14, 2007 04:40 PM
